Xeon Headlight Adjustment Instructions?
Mainly looking for the specs on where the projection line should be, and the amount of distance between the bulbs. Basically a document a service tech would use to adjust the lights during service.
It would be a similar process to what's seen in this video I'd imagine:
Thanks.
http://www.coolbulbs.com/HID-VISUAL-...-PROCEDURE.pdf
Now, I don't understand why you are trying to reaim the headlamps, if you have OEM Xenon headlamps, they are auto leveling and in order to aim them properly you would need STAR Diagnostics.
My car came with halogens and I switched to aftermarket HID's. I can clearly see the horizontal and vertical cutoff shapes and I just wanted to make sure they were correct.
Based on them originally being halogens, I'm assuming the adjustment is manual.
