Sponsored by: CARiD
iPhone 5S and COMAND
Old Mar 14, 2014 | 02:52 PM
sharpxia's Avatar
11' E350, 12' E550
I brought my MY12 E550 to the dealer yesterday, hopefully they have software update to support the iPhone 5S through the media interface. But they told me it is not supported yet. I want to know if anyone had their 5S working on their media interface yet? I know it worked through Bluetooth, so don't suggest I can use through Bluetooth. Thanks!
Old Mar 15, 2014 | 12:03 PM
drgallo's Avatar
2015 E400 4Matic Coupe
Mine works...
I used the Mercedes adapter cable that connects a 4/4S connector via the USB port in the center storage area. I bought the Apple adapter that is used to "adapt" the iπhone 5/5S/5C (about $29) and everything works fine. If you didn't get the Mercedes adapter cable when you bought your car, you can go on EBay and buy the newer Mercedes cable that connects the 5/5S/5C to the USB port without the need for the Apple adapter dongle.
I have a 2014 Mercedes E350 and my 5S works beautifully, either wired or wirelessly via Bluetooth.
Now what we REALLY need is the adapter to allow the iPhone to connect and use the CarPlay features (like Siri) that Apple announced this week. The good news is that Mercedes has said that they will be attempting to make AirPlay work with their existing cars.
Old Mar 15, 2014 | 01:02 PM
jerome8283's Avatar
GLS450
My iPhone 5 works with Bluetooth on my '10 e350. I had to get the firmware upgrade for it to work.
Old Mar 15, 2014 | 01:29 PM
bmeck2003's Avatar
2017 E300, 2017 C300
My iPhone 4S worked in my 2010 E350 coupe using the MB media cable. When I updated my phone to the 5S, I had to purchase the Apple 30 pin to the Lightning adapter to be able to connect the new iPhone.
Some people have purchased an aftermarket 30 pin to Lightening adapter and found that the adapter will not work with the Mercedes media cable. When they purchased a genuine Apple adapter, it worked.
Old Mar 15, 2014 | 09:09 PM
LasVegasMike's Avatar
2011 E350 Sedan
Sounds like car manufacturers are starting to retreat from their excitement about making this technology work with previous models:
http://www.macrumors.com/2014/03/14/...rplay-hurdles/
As they learn more about what is involved I'm sure they are weighing the investment cost versus the possible return, and my guess is that it's going to be a losing investment for them.
Old Mar 16, 2014 | 12:03 PM
sharpxia's Avatar
11' E350, 12' E550
I have bought the Mercedes lightning media interface cable from Mercedes dealer, but it says device incompatible when I plugged in my iPhone 5S. It is MY12, anyone has the same experience?
Old Mar 16, 2014 | 12:49 PM
shashivr4's Avatar
2013 E350 Sport Wagon - 4Matic
My cousin has the same problem on his 2012 E Coupe. My 2013 E Wagon works fine with the lightning cable from Mercedes. We are also puzzled. Please let me know if you figure it out.
Old Mar 16, 2014 | 12:54 PM
sharpxia's Avatar
11' E350, 12' E550
My dealership is looking at this for me this weekend, hopefully I will have a good answer on Monday. I think it is all software, they just need an upgraded driver that talks to iPhone 5S, the hardware is 100% capable doing that, unless Mercedes want you to buy a new car just because you upgraded a $200 phone.
Old Mar 18, 2014 | 01:51 AM
sharpxia's Avatar
11' E350, 12' E550
Finally, my dealer told me that the lightning media interface cable is only work for MY13 and up. They spent two days try to see if it works on MY12, but it doesn't, they have tried upgrade my COMAND system, but no luck. They finally give up. They said it requires a NTG 4.5 system, since mine is NTG 4.0.
Old Mar 18, 2014 | 01:23 PM
JoelE55's Avatar
07 E63 AMG / 07 C230 / 14 E350
iPhone 5 lightspeed is not compatible for MY12 or older. Its ONLY work for MY13-UP.
Old Mar 18, 2014 | 02:56 PM
sharpxia's Avatar
11' E350, 12' E550
Thanks for the heads up 24 hours after I have found out the answer from my dealer. Thanks anyway!
Old Mar 22, 2014 | 01:28 AM
Dema's Avatar
i535
Thanks for raising concern, I was thinking to buy 5S but not anymore
Old Mar 22, 2014 | 01:32 AM
sharpxia's Avatar
11' E350, 12' E550
You may still be able to use your iPhone 5S, here we are saying the MB lightning Media interface cable won't work on MY12 and below, but you may still be able to use it with Apple 30pin to lightning adapter to work with your COMAND.
Old Mar 25, 2014 | 01:48 AM
mofobaru's Avatar
2012 E350 BlueTEC
Same problem. I have the cable, part #003-827-09-04. I have an iPhone 5 connected to my 2012 E350. Doesn't work. Dealer says there is no new software.
Old Mar 25, 2014 | 01:56 AM
JoelE55's Avatar
You can return the cable since it's not compatible for MY12. It apply to newer vehicles MY13-up. Hopefully they can issue you credit.
Old Mar 25, 2014 | 12:28 PM
JoelE55's Avatar
Media Interface Cables with Lightning Adapter
. The model applicability was stated incorrectly and an updated version is listed below. Additionally it is important to know that only vehicles with Option Code 803(2013) or Option Code 804(2014) are applicable to have the cable installed.
Class Vehicle Model Year Part Number
C-Class Sedan W204
2013-2014 A003 827 09 04
C-Class Coupe C204
CLA-Class C117
CL-Class C216
CLS-Class C218
E-Class Coupe C207
E-Class Cabriolet A207
E-Class Sedan W212
E-Class Wagon S212
GLK-Class X204
GL-Class X166
ML-Class W166
S-Class V222
2014 A222 820 03 00
SL-Class R231
SLK-Class R172
2013-2014 A003 827 10 04
For older vehicles the Lightning Adapter from Apple can be used in conjunction with Media Interface.
Old Mar 26, 2014 | 08:50 PM
mofobaru's Avatar
2012 E350 BlueTEC
I returned it, no problems. So then I tried a 30-pin to Lightning adapter. That didn't work either. Guess I'll just use Bluetooth and charge it from the cigar lighter.
Old Mar 26, 2014 | 10:00 PM
sharpxia's Avatar
11' E350, 12' E550
The 30pin to lightning adapter worked fine on my MY12 E550. If yours is also MY12, you should ask your dealer to fix it for you.
Old Mar 27, 2014 | 11:24 AM
mofobaru's Avatar
2012 E350 BlueTEC
Maybe I'll try the Apple branded adapter. I was using one of those cheap ones. Thanks for the info!
