Sponsored by: CARiD
Remove airbag warning labels
Old Apr 19, 2014 | 10:47 PM
Arrie's Avatar
Anybody know how to remove the airbag warning labels from the sun visors without leaving the glue behind?
Old Apr 20, 2014 | 07:01 AM
hyperion667's Avatar
2012 CLS63
huge plus1
Old Apr 20, 2014 | 01:02 PM
eNNCity's Avatar
2013 E350
I've tried to figure this out in all the car's I've owned. I can't even get it to peel the slightest bit on the w212
Old Apr 20, 2014 | 01:11 PM
samkimg's Avatar
2023 XC60 PHEV, 2023 XC40 BEV
After a couple of years, my pax label just fell off of my 2010. The stealership accomodated a request to remove the second one at the next service. Don't know what they used, but it left no trace.
Old Apr 20, 2014 | 01:12 PM
drsaab's Avatar
Isn't it kinda illegal. Like removing the tag off a stuffed animal that says do not remove
Old Apr 20, 2014 | 01:52 PM
Tjdehya's Avatar
2023 AMG EQS
You can check Ebay for custom stickers. Most people place custom stickers over it.
Old Apr 20, 2014 | 10:22 PM
Arrie's Avatar
I don't think it is illegal to remove these stickers from your own car but surely it is illegal for the dealer to sell the car without them.
I have this 2010 E550 that I bought about a year used and clearly these warning stickers in my car are not from the factory. They are way too close to the edge of the visor and on the passenger side the sticker is severely crooked. It is obvious that these stickers were installed later and probably at the time when the car was CPO'ed for resell.
It seems the first owner was able to remove the stickers without leaving glue behind.
I can easily pull the stickers off but it leaves some glue on the visor. Should I just remove the stickers and let the glue dry and then just "dust" it off?
Old Apr 21, 2014 | 03:55 AM
belarus27's Avatar
2010 e550 p2
...or you could use that carpet/interior cleaner to help clean afterwords ???
Old Apr 21, 2014 | 08:19 AM
ttoE550's Avatar
2015 GL450
I used this method on a previous Porsche I owned.
http://www.n54tech.com/forums/showthread.php?t=18406
It worked very easily.
The method warns of a ghost of the sticker, but I did not see one. This might be an age/sunlight issue as the area under the sticker is more protected from sunlight and dirt, etc. My car was nearly new when I did it, so less of an issue.
I'm not responsible for screwing up your car if you try it. Have you looked into getting new visors?
Old Apr 21, 2014 | 12:12 PM
Arrie's Avatar
I don't want any ugly stickers on the visors as the stickers show outside when the visors are down.
Old Apr 21, 2014 | 06:30 PM
imaphaetonguy's Avatar
GLC300
GOT IT!
Removed my stickers in 5 minutes with NO CHEMICALS. (cloth visors)
I used my wife's hair dryer (lord knows I haven't needed one of these for about 15 years).
Set it on HIGH for about 4 minutes, and the label started to lift.
Got it off in two pieces - no glue residue. Second one off in one piece.
Now - go out and SPREAD THE WORD!
Old Apr 21, 2014 | 07:23 PM
MBNUT1's Avatar
2010 E350 4Matic
Originally Posted by imaphaetonguy
GOT IT!
I would be afraid of damaging what was underneath. Once you got it off you could use goo gone. In fact I wonder if you put goo gone on the sticker if that would help get it off.
Old Apr 21, 2014 | 10:58 PM
audi40's Avatar
2020 GLE 450
Rubbing alcohol...
http://forums.audiworld.com/showthre...=Visor+sticker
