Sponsored by: CARiD
Accessory rear entertainment question
Old Aug 23, 2014 | 03:43 PM
ucla95's Avatar
E63S, RRS SVR
There are USB ports, can I load movies or TV shows on to a thumb drive and play them on the screens? Thanks in advance!
Old Aug 23, 2014 | 04:33 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Not going with 864 factory rear seat entertainment? The screens are an inch larger with 864 vs the accessory among some other differences.
Old Aug 23, 2014 | 04:53 PM
ucla95's Avatar
E63S, RRS SVR
But only has DVD and composite video inputs.
What are the other differences besides screen size?
Old Aug 24, 2014 | 03:50 AM
IMO it looks much better integrated with the interior color and shape of the seat than the accessory version.
I know the 864 version talks with the front head unit- not sure if the accessory one does. This way if I have a DVD in the front changer and a DVD in the rear player each screen can play a separate DVD. I also think that you may be able to listen to/use media hooked up in the armrest such as the USB/Media Cable/iPod cable to use it in the rear. I think the head unit also has an SD reader in it so maybe that can be used to watch stuff in the rear as well- not totally sure.
It'd probably be best to find a car at your dealer with the rear seat entertainment system and play around with it to see if it does what you want it to do. Note, the ML/GL/last gen S all use the same system (at least the screens look the same and uses the same headunit software) so it should act the same as the E. It'll be easy to find an ML or GL on the lot with this option to play with.
