Setting New Cruise Speed
Also, when changing the cruise speed with the lever it will only increment in 5 mph increments. What if I want to set a new cruise speed of 63? I can set 60 or 65 with the lever. The manual states the exact same procedure for setting in 5 MPH increments as well as 1 MPH increments.
Every time the cruise control lever is pressed up or down the last speed stored is increased or reduced.
To adjust the set speed in 5 mph increments (10 km/h increments): briefly press the cruise control lever up or down to the pressure point. Every time the cruise control lever is pressed up or down the last speed stored is increased or reduced.
To change the speed you must first cancel cruse by pushing forward or hitting the break. Pulling it back will resume the last set speed. If you want your current set speed push up to the first pressure point and that will set your speed to the current (or 1 mph above current) speed.
Basically there is no dedicated "set" function.
I've driven lots of different cruise controls and I believe I was expecting this one to act like all the others where every time you activate, it sets the current speed and there was a Resume action for resuming.
On another note, I felt that the lever is too much like a blinker and have inadvertently hit it when I was actually trying to turn the blinker on. After about a month of driving it I am just now getting used to it.
Your info here is a bit misleading.
To set a new speed at any time is just to move the CC stalk up or down at any speed when it is not active meaning after you have hit the brakes and you are accelerating or decelerating. If you pull the stalk you will get the car to go after the last speed set point.
Pulling the stalk will set the current vehicle speed as the set point ONLY when the cruise control has not been used after the last start of the car.
