Key FOB Battery Life
#51
Received 1,489 Likes
For those of us who have "older" keys that continuously "pings" and leaves the keys in close proximity, probably best to store one's keys in a tin can or the like to stop the 'pinging' from getting out.
It works for me as when I have my keys in a tin can and I try to open the car with the keys in there, my w212 does not unlock/lock. I am not sure if this is a long term remedy but it works and thus its a very basic DIY. Unless there are other suggestions...
#52
Received 1,751 Likes
2016 E350 Sport
It's called a Faraday cage. There's all different types on Amazon. This one for under $10 even has a picture of an MB key in it.
https://www.amazon.com/Upgraded-Faraday-TICONN-Premium-Protector/dp/B07GDD35GH
For this reason, I doubt that the fold-over pouch type found on Amazon will work as the fold doesn’t seal perfectly.
My second experiment works perfectly. I shopped a resale store for an aluminum cup with a sealing aluminum lid. I had to buy two items, one the cup, and a second jar (glass) with an aluminum lid. Altogether, I spent $1.60 for both items. Sit the glass jar aside.
The aluminum lid from the glass jar nests into the cup perfectly (albeit upside-down), and the sealing edge of the lid is deep enough to seal both parts together without fail.
In use, I can lock the car, then place the key within the cup, install the lid, and sit it on the ground 2 feet from the car door. After repeated attempts, the car will NOT unlock when I insert my hand through the door handle.
Once satisfied that it worked, I then added some colorful padding within the cup to eliminate key rubbing on the hard aluminum interior. And I super-glued a plastic bottle cap to the lid to provide a grip to pull the lid out of the cup.
The completed faraday cup sits on my dresser inside a walk-in closet, 75 feet from the car in the garage. It takes hardly any room at all. And even though I live in an area that hasn't seen any crime in decades, no one driving by can hijack the signal from the key and relay it to the car. Not that they can open the garage door to get at the car anyways.
#53
I need to try and see if this works with an older fob like mine (2012)
#54
It usually lights up the red indicator on the fob a little longer when that works. I'm not entirely sure starting which year and which models they started doing this. It's part of most recent (2-3 years) keyfobs at least.
#55
My 2014 functions that way. Yes the LED will pause when flashing to let you know it is engaged.
#56
2016 E350 Sport
The key fobs for my 2001 C-Class work this way to turn them off. So this is not new.
#57
On our 2013 with Keyless Go we were mowing through FOB batteries when we left them with all our other keys in a kitchen drawer, 10 or so feet from the car.
We moved both FOBs to a drawer in our Master and the battery life has notably improved - probably 25-30 feet away now. I think I might put a small tin can in the drawer, or line it with foil, now that I've been reading this thread... I do believe the keys are continuously trying to keep in contact with the car if they are within range.
#58
Received 1,736 Likes
1922 Ford Model T / no OBD
I tried double close click on my 2014 model.
No kudos - the door will still open with hand pull.
#59
I've tried many different brands, Energizer, Sony, Duracell, Panasonic, they all lasted about the same amount of time. The energizers tended to have the highest starting voltage. I believe they're Panasonic from the dealer. Doesn't seem to make a difference. Going to stick with Energizers.
#60
Received 3,925 Likes
2017 GLE350 4MATIC
On my W166 I received the "key not detected" message in the MFD. I replaced the fob battery and all good. The fob battery was one year old.
#63
So what I understand from the system and correct me if I am wrong.
-key sends pings all the time and usually batteries last over a year
-there is no motion switch in the key.
-you can screen the key to prevent car theft, but that will have no effect on battery life
- pressing the button has to shorten the battery life, but that might be hard to estimate by how much.
So for those complains about short battery live, could it be they press the buttons often, or keep the button pressed in their pocket?
#64
#66
#67
Actually CR2032 will fit the MB key. difference between 2025 and 2032 is one is 2.5mm thick while the other is 3.2mm thick.
2032 also has more power. Both are 3V, but 2025 is about 150mah while 2032 is about 200 to 225mah so close to a 50% increase in power.
It takes a little bit of pressure to push a 2032 into the battery compartment of the key but it does work. (tested it myself).
I'm actually using 2032's now in my key since I work in IT, do a lot of computer work and thus buy and use a lot of 2032 batteries.
#68
2016 E350 Sport
I can't fit a CR2032 battery into my fob for all the tea in China.
On balance, I'll take the first statement before the second any day.
