Sponsored by: CARiD
are my doors not alligned correctly??
Old Feb 20, 2015 | 11:50 AM
Carpenter Maass's Avatar
2012 W212 BlueTEC
I had a major rear end collision that resulted in my vehicle being in the shop for three months. Since then I have noticed increased wind noise coming from the rear doors. please look at the attached photos... something looks off to me. thanks for the feedback. http://imgur.com/TfjCrch other side is nearly as uneven.
Old Feb 20, 2015 | 01:03 PM
konigstiger's Avatar
'71 Pinto
Have them confirm gap dimensions are correct.
File Type: pdf
Old Feb 20, 2015 | 01:16 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Cut someone inch strips of paper from a 8x11sheet.
Take one strip of paper and place it in the door area of the open door. Close the door and try to pullout the paper, try different areas around the door seal including above where the glass is. Try this on the front door first to feel the resistance of the door rubber seal.
Old Feb 21, 2015 | 02:48 PM
dbldpr's Avatar
Veteran: Navy
I do not want to sound bad but why would you keep a car that was in that bad of an accident where they took 3 months to fix. I hate to say it but if it was that damaged you will continually have problem as long as you own it. If you can afford it I would suggest getting rid of the car and get another one.
Old Feb 21, 2015 | 08:55 PM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
3 months, whoa? Was it close to a total? What did repair bill come to?
Old Feb 22, 2015 | 12:01 AM
2012 W212 BlueTEC
Repair bill came to 21k. Everything seemed fine once I received the car but I did notice an increase in road noise bleeding into the cabin... I finally figured out why after staring at another e350 next to mine. the trim on the rear Windows is way off and I am not sure if that's because the doors were not mounted correctly after the repair or if the force of the impact slightly distorted the shape of the rear passenger door wells. Selling the car at this point is out of the question as I am pretty much saddled with it unless I lie about the vehicle history to the next potential buyer (which is out of the question of course)
Old Feb 22, 2015 | 12:28 AM
Case1906's Avatar
Tough situation. One of my friends had a similar situation and repair bill with a CTS-V. He never felt good about the car and traded it for a BMW 5 Series. If you aren't happy, I agree with dbldpr -- take a hit and get out of it. Good luck.
