Sponsored by: CARiD
Airmatic question
Old Mar 3, 2015 | 10:09 AM
Airmousam's Avatar
2010 E550 4M P2 Distronic, CLK550 Cab P2
Airmatic question
New to airmatic....I leave the car in comfort mode in the winter, small red light for Comfort on center console is lit. Should the car stay in it's 'raised' position even after the car is turned off and sitting? I find myself having to raise the car when I get underway and that could be perfectly normal, just trying to find out. Would think if it remains in comfort it would raise automatically when I start to drive. Thx much!!
Old Mar 3, 2015 | 10:17 AM
RA72825's Avatar
My car will self level when I pull into the garage and turn it off. It hisses, farts, and makes other odd sounds then quiets down and goes to sleep after a few minutes. When I start it the compressor will run and self adjust as I back out and head out. I am always in normal mode. I rarely put it in the sport mode. If you keep your tires air at 35-36 lb., that is usually a harsh enough ride for most people with 18" wheels. I never ever touch the raise button to move the suspension.
Old Mar 3, 2015 | 11:42 AM
wanderfalke's Avatar
e550
The raised button is to lift the front for steep driveways ect. . It is in addition to the comfort mode. The car lowers back to normal comfort mode at highway speeds.
Old Mar 3, 2015 | 01:51 PM
Airmousam's Avatar
Bingo, thank you!!!
Old Mar 6, 2015 | 03:22 AM
Arrie's Avatar
It raises both front and rear.
Old Mar 6, 2015 | 10:08 AM
johnfrancisco's Avatar
2011 Mercedes-Benz E350 Wagon (Sport)
Cold weather & rear Airmatic Suspension.
My wagon will turn into a lowrider sometimes after only a couple hours parked, not every time
, but at least once or twice a week. It looks cool, but could there be a leak in the bags?
Old Mar 6, 2015 | 11:40 AM
konigstiger's Avatar
'71 Pinto
Originally Posted by johnfrancisco
My wagon will turn into a lowrider sometimes after only a couple hours parked, not every time, but at least once or twice a week.
Wagon up to VIN 596462 reference bulletin LI32.22-P-048597 for warranty repair https://mbworld.org/forums/e-class-w...ml#post3917691
Old Mar 6, 2015 | 11:42 AM
RA72825's Avatar
Sure sounds like a leaking rear air bag, but it would occur pretty regularly and not a spotty occurrence as you have described. Get it checked out
