2010 vs 2014 Suspension on Rough Roads - Help
As for your 2010, have you had the shocks replaced at all in the past 5-6 years? You'd be amazed the difference it can make if they are worn or leaking. The test is to go out to your car and push up and down on the front corner of the hood. The car should bounce down, bounce up and then immediately come to a rest. If it keeps bouncing up and down, you might want to have a mechanic look at the suspension/shocks.
