Sponsored by: CARiD
Audio aux not available while iPod is connected
Old May 7, 2015 | 03:58 PM
IDIOFFO's Avatar
2010 E550 P2 / 2003 S430
Hi guys I have a 2010 E550, whenever I want to use the audio aux I need to disconnect the iPod first while I have a y connector with aux and iPod connection. I was wondering if there was a way to have audio aux to work without having to always disconnect the iPod first. Thanks guys
Old May 7, 2015 | 05:59 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
noticed that too. Seems like the cable can only be recognized as one thing at a time.
Old May 8, 2015 | 01:11 PM
IDIOFFO's Avatar
I wonder if anyone has a solution for that
Old May 9, 2015 | 12:58 PM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
Cannot recall an issue when I used an iPod. I use my iPhone in BT mode now unless I want full register access and I plug it in.
Are you using the cable in the glove box?
Maybe I am not clear as to what the problem is.
Old May 9, 2015 | 07:54 PM
thefisch's Avatar
Top Answer: 1
yes, cable in the glovebox. We are talking about a cable connected ipod not streaming via BT. I think the cable can only recognize one source at a time even though it has two inputs. Likely designed that way.
Old May 9, 2015 | 08:06 PM
belarus27's Avatar
2010 e550 p2
i noticed same thing too , you have to unplug the ipod if you wanna play via aux...weird
Old May 9, 2015 | 09:15 PM
My iPod when I used it did not have BT capability so you must have something different.
My iPhone 5 works fine in BT mode and if I want full register info I plug it in.
Sorry I can offer more.
Old May 9, 2015 | 09:47 PM
IDIOFFO's Avatar
Yes it weird, stupid too that you will have to unplug the iPod in order to use the aux. I have been trying to find a solution to have aux working without having to disconnect the iPod but no luck so far. Also i was able to activate BT audio through the engineer mode but it seems not to want to connect to my iPhone, therefore BT audio is useless for me
