Sponsored by: CARiD
E63 brakes on E350
Old May 13, 2015 | 07:09 PM
MG21's Avatar
99clk cabriolet, 2014 E350, 2020 C63S
E63 brakes on E350
Will the brakes from a 2011 E63 work on a 2013 E350? i found a good deal on a used set. Any help is much appreciated.
Old May 13, 2015 | 07:55 PM
PeterUbers's Avatar
Like ... Calipers and pads and rotors?
Or just pads
What does "brakes" mean in this context
But the simple answer is no
Old May 13, 2015 | 07:57 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
You should first check on pad and replacement rotor prices for a 2011 E63. The cost of the wear out parts may shock you. Also the hubs are different as are the axles. So is it possible, yes, if you have money to burn.
Old May 13, 2015 | 11:35 PM
MG21's Avatar
Or just pads
sorry for not clarifying myself. I can get rotors, calipers and pads. will they work? what else will I need?
Old May 13, 2015 | 11:36 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
^^+1 on the above responses.
brake components are usually the fastest to wear and most expensive to replace on an AMG. just something to think about before you pull the trigger.
Old May 13, 2015 | 11:37 PM
MG21's Avatar
Thanks for the response.
Im aware of the prices for the replacements. What mods would need to be done to get them to work?
Old May 13, 2015 | 11:58 PM
Mods may include new front axles, new hoses, new bearings, new hubs, new ball joints and upper and lower control arms and bushings and maybe new master cylinder and braking system under the hood. Going with after market Brembo brake package for your car will cost less and be easier.
Old May 14, 2015 | 12:44 AM
FAMUBER's Avatar
w212 & s212
I actually did a e63 brake swap on my e350. found a set of calipers/pads/rotors at a junk yard for $2k. painted, replaced the pads and installed for about $800. that would beat any after market brembo brake package if you really found a good deal like you said.
i'm not a mechanic and I had my brakes installed about 3 years ago but from what i remembered, it was pretty much a direct swap. the only thing i recall is having to use a different bolt somewhere but that was about it. stancelab has a w212 with the same swap as well so i'm sure they can give you better info about the installation.
everyone else is right about burning money. unless you can get parts at wholesale price, the front amg rotors had a price of 1500 for the pair. luckily i do get it pretty cheap so i have no regrets. my fav mod so far
Old May 14, 2015 | 12:48 AM
MG21's Avatar
Thanks for the response, the set i found is for around the same price. Calipers, rotors, pads. I will replace the pads and lines with new ones.
Old May 14, 2015 | 12:50 AM
MG21's Avatar
Car looks very nice btw. Good job.
Old May 14, 2015 | 01:00 AM
FAMUBER's Avatar
w212 & s212
thanks! i avoided the oem pads because of large amount of brake dust. i went with posi quiet which barely create any brake dust. unfortunately the ceramic pads are made for the front only
Old May 14, 2015 | 01:12 AM
MG21's Avatar
Are you using the original E63 rotors? Did you have to modify anything else?
Old May 14, 2015 | 01:20 AM
beejAMG's Avatar
OFF TOPIC...Nice stance mate. what are you lowered on? wheels and tyres specs?
Old May 14, 2015 | 01:32 AM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
Would you guys educate me on the differences between OEM and AMG brake system ?
For better brake distance ? or something else ?
Old May 14, 2015 | 01:41 AM
FAMUBER's Avatar
w212 & s212
yes I am using oem e63 rotors. the ones in the picture are brand new ones that I recently changed to.
thanks. lowered on kw v1 coilovers. wheels are front 20x9.5 on 225/35, rear 20x11 on 255/35.
honestly, i did it for the looks but yes the braking power is noticeable and i would say these prevented me from a few rear ends
Old May 14, 2015 | 02:23 AM
beejAMG's Avatar
what offsets F/R? Any rubbing issue with that height?
Old May 17, 2015 | 11:20 AM
FAMUBER's Avatar
w212 & s212
sorry I wish I knew my offsets. had some problems with the whole process and never got the numbers.
no rubbing issues at all. with 2 people sitting in the back, the fender will sit right next to the lip. if my tires were not stretched, it would be running all day long
Old May 18, 2015 | 03:32 PM
AMGAffalterbach's Avatar
2014 BMW M235i
If you are going for looks then I can see a purpose, but if it's the performance you're after, better tires will do a lot more for braking performance than bigger brakes with larger calipers up to a certain point - basically saying that the better performance upgrade is a high end set of tires instead of an overkill braking system, but that's just my 2c
Old May 18, 2015 | 10:46 PM
beejAMG's Avatar
c2xbenzo: cheers mate! your car looks awesome!
AMG: Ive never known anybody who upgraded to bigger brakes for performance. it always comes second to looks. and anybody who says otherwise is a liar.
I couldnt agree with you more. but if the OP has the money to spend for the mod, id say go for it. im sure you'll feel happy everytime you look at them calipers! then sad everytime you replace them.
Old May 18, 2015 | 11:10 PM
FAMUBER's Avatar
w212 & s212
like I said before, my fav mod so far. it's expensive but there is no point in getting nice rims when you open the window wide open for people to see a set of small rotors and ****ty looking calipers. didn't really notice it until after i got my own bbk
Old May 19, 2015 | 03:48 AM
MG21's Avatar
Got the rotors and the calipers. New wheels are on order and should be here beginning of June. Gonna upgrade my brake lines and powder coat the calipers and put on new pads before i mount them up. Thanks for the input.
Old May 19, 2015 | 09:38 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Swapping to the E63 brakes just increased the unsprung weight. This is where the suspension engineers recalibrate the spring rate plus the shock absorber compression and rebound damping. TANSTAAFL.
Old May 19, 2015 | 12:13 PM
pamiboy's Avatar
E 350
Now what about the rest of the upgrade (apart from the brakes). I mean the exhaust, suspension, transmission, engine, etc and finally the AMG badge !!!.
Old Aug 7, 2015 | 10:25 AM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
Lol^
I think it looks nice. Good job.
Old Jul 12, 2016 | 07:03 PM
Mrmendoza's Avatar
2019 C43 AMG
Looks good! you got a steal on the brakes!
