Spoiler keeps peeling off
This is exactly why I paid the dealer premium price because I would be screwed if I installed it myself or had a local bodyshop do it and this happened. But what can I or the dealer do to keep this damn thing stuck to the trunk? I'm already waiting at least a week before washing the car when they install them.
First peel:
Second peel (now):
They won't fix it. You will have to do it yourself.
Try this:
http://www.gorillatough.com/gorilla-mounting-tape
it's like when Jerry returned the jacket out of spite
fwiw: same thing is happening on my 550
In any case, you paid premium for it so the dealer is to fix it.
I had an issue like yours and my dealer replaced the spoiler and it has stayed on. However I also had the rear window spoiler come loose at ends and this one I fixed myself with 3M tape. It has been fine. No worries to damage paint doing it as it glues on the window glass.
If they tell you they cannot do any better job ask them to remove it and return all of the money you paid for it. And don't go with their store credit, demand the money back as this is what will make them to try harder. No business want to return money...
You could also offer to buy the spoiler after removed for the cost you could buy one in eBay or somewhere else and then install it yourself using good tape. But don't let these "Best or nothing" people off too easily as if the spoiler tape fails on the trunk side your dealer service guy doing is not up to the task to do it correctly.
now, to make it a BIT more permanent. I also put just enough silicone glue on it (just enough not to make a mess when pressed down with pressure) and held it down with masking tape overnight. its NOT permanent and you can easily remove it cleanly and without any damage to your paint should you wish to remove the spoiler. but itll hold better than double sided tape alone. your call mate.
http://3mcollision.com/3m-automotive...397-black.html
I used a heat gun to warm the hood nice and toasty after cleaning with Palmolive and rubbing alcohol ... The 3M heavy duty tape has worked just fine ... Home Depot
Did the same on my TL and no issues for 100k miles in all severe weather extremes of Chicago
