Panoramic roof question rear sunshade related
Thank you so much for your time and help.
The front sections sunshade works perfectly as does the one on the rear window.... it's just the rear panoramic section that is missing/not functional.
Or while I can not imagine it that it's likely, is there not a sunshade for the back half of the pano roof in the w212?
If there is no shade in the rear of the pano moving when the front section is moving it is quite simply missing? I would contact the dealer because you will want this sunshade. Don't know where you are located but no matter where the sun shines you will want to block it at some point. Good Luck.
When the rear sunshade rolls up (is open), is it stored in the center pillar like the front one, or in the rear of the car and opens forward directionally like the front (opening outward from the center support pillar towards both ends of the car). When the front sun shade is closed, you can see the shade retracted, the rear of mine does not have this, It's difficult to explain, however I'm curious if the shade broke free and wrapped up with the front shade, or was literally removed entirely from the vehicle. I'm also curious if there is a motor or some other elastic type of retaining system to "pull" the shade in the direction it needs to go to open.
I'm pretty confident the shade malfunctioned and rather than repairing it, the front was retracted and the assembly was literally torn out... the rear roof and pillar panels are a touch loose so it was removed at some point and not re installed 100% correctly. I HATE interior panel work!!
The shades for front and rear panels are stored in the centre and both retracts or expands simultaneously when you press the button.
That helped a lot. Ironically I went into the dealership near my house and got the part diagram and some pricing. It looks like a replacement shade (front and rear are 1 part) is 468, the cable is 113, and the two brackets that the rear of the shade are supported by are 41. The labor is 8 hours @ 136/hr. There is VERY little I will not do myself on a car and a friend of mine is an indy mercedes mechanic but I'm hesitant to do that all myself as I want zero rattles and body panels NEVER go back together as well as how they come from the factory.
Where the diagram fails to make any sense is that the front shade appears to have a cable that runs from the front of the overhead area and pulls the front shade open. The rear does not appear to have anything to support or tension the rear portion of the shade to pull it back... with how flimsy this portion of the shade is, I can't imagine simply unrolling pulls it to the rear. Can you see a cable or anything that draws it to the rear? I need a part list for the dealer that I purchased it from to make the claim and I don't fully understand the mechanics of the shades rear operation. If any of you have had the system apart and know how that rear shade is pushed backwards or pulled backwards that knowledge would be great.
Alternatively if someone has access to the service manual for a sunshade replacement I would be forever in your debt!
Part 250 are the cables that drive... the rears do not show any parts that would offer the tension which is my confusion and the current (320) brackets in the rear that the shade was removed from flop around like an abacus (chinese counting thing/calculator).... when the front screen actuates nothing moves in the rear. I know the diagrams are never really accurate but that seems like a pretty significant item that is missing.... When I talked to the tech at the dealership they did not even know the shade f/r was one piece so anything they said couldn't point me in the right direction.
Has anyone here replaced it or could they point me in a direction of where I can access a service manual?
Thanks again.
I pulled the rear of the headliner down and exposed a few torx head screws that can be removed holding the track in place. (first remove the rear center section of the headliner with a tug, and both rear grab handles). you can then carefully pry down the back of the track to replace the little shade retainers (which were broken in my case). replace them and replace the screws. Carefully pull the shade back, wrapped upon itself and then it sort of rolls over into the new brackets.
What isn't shown in the diagram is the front cables/rods "push" the small retainers backwards to hold the shade closed. when open, this rod moves back to the front of the car allowing it to close. It is similar to a window shade and is spring loaded. The rod is in the track itself and about the only way to even see it is to shine a flashlight upwards in the car and see it in the reflection. While the Service Manual would like you to drop the entire headliner and track, you can do this from the rear but it requires a bit of finesse so be careful. Also be careful as you can tear the shade (I nicked mine), and the brackets are easy to break. I discovered the "roll the shade onto the bracket technique after breaking one of the replacements while attempting to put them both into the shade and slide it on assembled from the rear. Epoxy is curing now and hopefully will fix it so I don't have to drop the headliner again!!! It isn't terribly hard to do and much better than the 1000-1200 in labor Benz charges
