Sponsored by: CARiD
hello , help with my problem please
Old Jun 30, 2015 | 07:33 PM
same350's Avatar
2010 mercedes e350
hello all.
my name is sam , i am new to the forum, i am an owner of a 2010 e350, unfortunatly i am having a problem with my car, i attached a vid maybe someone can identify the cause , note that it happen when making a turn at low speeds, the vid was taken when the car was stationary in a hill leaving my parking spot!
i am under the impression it is a bad ball joint ( not sure upper or lower) having took it to a mechanic yet!
thanks
sam
File Type: mov
Old Jul 2, 2015 | 09:03 AM
Sean1234's Avatar
2010 E550 4Matic, P1, P2
have the brakes been done on the car?
Old Jul 2, 2015 | 10:17 AM
samaritrey's Avatar
Super Moderator
THE C350
Curious how many miles are on the car?
Old Jul 2, 2015 | 12:57 PM
same350's Avatar
2010 mercedes e350
no, i was thinking of changing the brake pads within a month or two.
Old Jul 2, 2015 | 12:58 PM
same350's Avatar
2010 mercedes e350
85k miles
Old Jul 2, 2015 | 06:07 PM
Arrie's Avatar
Originally Posted by same350
hello all.
thanks
sam
So you hear this when you turn the wheel, right?
Probably is a dry load carrying ball joint in front. That should be the lower joint on either side.
Old Jul 2, 2015 | 06:29 PM
same350's Avatar
2010 mercedes e350
yes, when i turn the wheel.
i passed by the mechanic , and he comfirmed it was the lower ball joint on the right side.
Old Jul 3, 2015 | 08:45 AM
Sean1234's Avatar
I had the same thing on my E550 with 95km on it. Ended up the brake pads and rotors were so warn that they were rubbing. Have the brakes checked before anything else.
