Sponsored by: CARiD
Oil Sensor Warning Light
Old Aug 14, 2015 | 02:00 PM
toddlaroche's Avatar
2002 E320 4Matic
The oil sensor warning light comes on in my 2002 E320 with 110K miles on it. It always comes on just as the engine oil heats up to normal operating temperature. Is this a DYI fix? What's involved?
Old Aug 14, 2015 | 05:01 PM
konigstiger's Avatar
'71 Pinto
May need to replace oil sensor shown here http://workshop-manuals.com/mercedes...ir/procedures/
Old Apr 13, 2022 | 09:47 PM
T100T's Avatar
Top Answer: 1
2010 E550
After a routine oil change the "check oil level at next refueling" message appeared, checked oil level, it was a little high but even after removing to where level is at mid-point on the dipstick the message still appears. Am thinking the sensor has gone bad - are there any electrical checks for this part or is it straight to replacing? There aren't many posts on this part; it doesn't seem difficult to replace, my question is do I need a gasket for the lower oil pan? Vehicle is a 2010 E550, 140 k miles. Thanks for any help.
Peter
Old Apr 14, 2022 | 02:57 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
seal ...
Part #11 looks like an O-Ring for sensor #5, right?
Old Apr 14, 2022 | 08:18 AM
T100T's Avatar
Top Answer: 1
2010 E550
Thank you for replying, based on the Amazon picture,
Amazon.com: Hella 008891011 Engine Oil Level Sensor : Automotive Amazon.com: Hella 008891011 Engine Oil Level Sensor : Automotive
, that seal comes with the sensor, I was referring to whether there was a gasket for the oil pan itself, where it mates to the engine.
Old Apr 14, 2022 | 01:04 PM
pan seal
oil pan seal is hand made with RTV silicone.
