Slugish soft acceleration
I've been servicing it as required and mostly I use it around town and to go to work which requires about 15min on the highway.
Have any of you have a similar experience? Any ideas on what it might be? Do I need to change the spark plugs or something???
1. Get in car and close the door.
2. Turn key to position 2 (or press the start button twice) with feet off the pedals, i.e. do NOT start the engine.
3. Floor the gas pedal and keep it down waiting 10 seconds when you will turn the key to position 1 (or press the start button once) still keeping the gas pedal down.
4. After key in position 1 lift you foot from the gas pedal and wait about two minutes. In my car the cluster goes black after about 20 seconds but then pops up again after about two minutes. Anyhow, wait two minutes no matter what happens.
5. Turn key off.
5. Turn key off.
With the Keyless Go button inserted:
1) foot off the brake during the whole procedure
2) press the Keyless Go Start button once
3) press the accelerator to the floor and hold for 5 seconds
4) press the Keyless Go Start button twice to turn off the ignition
5) release the gas pedal
6) Wait at least two minutes before starting the car.
The Keyless Go Start button does come out of the ignition switch - it may be a little hard to get out but I was able to pop mine out with a little effort. Then follow the normal procedure:
1) ignition switch to position 1
2) push the gas pedal to the floor and hold for 5 seconds
3) turn the ignition switch to the off (0) position
4) release the gas pedal
5) wait at least two minutes before starting the car.
5. Turn key off.
I have never done it with the windows/sunroof open and I have not had an issue afterwards. Other than that one comment noted above, I have only seen posts about it affecting throttle response and shift points.
5. Turn key off.
For 2 years now I've just chalked it up that E's had rough transmission shifts until I performed the reset yesterday. Wow, what a difference! Loving my car all over again...no more jerking down shifts & smoother/higher shift points. Great forum posts fellas.
I hope the fix sticks for you and does not return. Obviously you could do the procedure again. But my concern for you is that there is a larger problem looming with past rough shift points. It's seems illogical that an adaptive feature would lead to roughness. Instead I worry that your tranny just has problems with lower shift points and the reset raised them for you. Time will tell.
My understanding is that the adaptive transmission is designed to tailor to the driver's style so the more leisurely you drive the lower the shift points. After a reset, I notice it holds the gear longer when I drive slowly (like an old man according to my wife). But I like it that way. Over time it starts to anticipate that and shift earlier and eventually I get frustrated having to mash the pedal for a 'proper' reaction. Then I remember to do a reset and it feels like a new car. Personally I would rather the car stay the same and let my right foot adapt depending on the situation rather than the other way around.
