Sponsored by: CARiD
2007 e550 4matic Air Ride Problem
Old Oct 15, 2015 | 11:23 AM
mafap's Avatar
2007 e550 4matic
Hello,
I have a 2007 e550 4matic:
the right front strut started leaking so i had it changed, car was perfect for a year.
Now the air ride compressor will not come on to adjust the heights and i get the message "malfunction"
Heres the tricky part...................... after checking all connections and changing the relay I discovered that if i disconnect the plug to the air suspension valve block... the pump comes on and all seems to work perfect except the malfunction light come on.
Question is, what would make this happen ?
Attached is a picture of the plug that is disconnected
there was a code: 5507 suspension strut is implausible, but i think that might have been from when the rf was changed.
Thanks for any help.
Old Oct 15, 2015 | 11:42 AM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
Try the W211 forum.
Old Oct 15, 2015 | 01:19 PM
mafap's Avatar
2007 e550 4matic
Will Do Thanks
