Techron question...which one?
1. Techron concentrate plus complete fuel system cleaner
or
2. Techron fuel injector cleaner
I have been use that on my other vehicles(Honda, VW) too and it does wonder.
That said, I'm an old school guy and add some techron every 10K because I've done this for decades. I've spent money in worse ways (like all those $ bills at strip joints in youth.
The second one is not the concentrate - it is the one that you add with each fill up to supposedly get the some benefits as using chevron gas.
I use the first one maybe one or twice a year. Just makes me feel good.
looking to use it twice between oil changes.
I wouldn't put this in my AMG but always wondered if this stuff is really effective or just snake oil.
In general, fuel additives are usually harmless - in most cases the worst they'll do is waste your money, but oil additives can cause some serious harm.
As said by a couple members already, put a Top Tier gasoline in your car each time you fill, and you won't need to purchase any cleaners.
My main reason for using it is because my local dealers push fuel service on all my cars and want $80-$150 for the service depending on the car. I buy a techron concentrate bottle for $6 on sale for a once a year treatment and then tell them I already got the fuel service done. Not saying either techron or their stuff makes any difference, but I haven't found any information that shows the stuff the dealer uses if any better than techron concentrate. So $6 for peace of mind once a year.
You're using the right word when you say your dealer is 'pushing' the fuel service. Next time he does this, ask him where in your maintenance manual this service is listed. He's just selling you a very profitable service - one that you don't need.
I hate to be repetitive, but just use a top-tier gasoline, and you have no need to ever add anything to your fuel. - Other than a stabilizer if you're storing the car.
the Operator's Manual does have a blanket statement about not using additives.
Found out my dealer was adding it as part of "A" and "B" services anyway.
I still add Techron about twice a year even though I use Top Tier 93 octane gas.
BTW, the gasoline additives are added at the "tank farms" to each tank truck as it picks up the fuel. The additives are different, if any at all. They are determined by the retailer who is receiving the load or by direction of the "brand" of the gasoline.
How accurate are they in adding the additives, especially considering this is also where they add the 10% ethanol to the load?
I do know that if I had a DI engine I would definitely be using it as tests on deposits point to elements only present in gasoline. Evidently those elements are only found in US refined gas so you don't see the DI carbon buildup in European engines.
- If I already use Chevron, Texaco or Caltex with Techron fuel, do I need to use Techron Concentrate Plus as well?
If you are using a high-quality gasoline such as Chevron, Texaco or Caltex with Techron exclusively, you do not need Techron Concentrate Plus. However, if you occasionally fill up with lower quality gasoline, Techron Concentrate Plus can help clean up deposits that can form over time. In addition, if you have an engine that is sensitive to deposit formation, or if your vehicle is regularly used under severe conditions, you may benefit from using Techron Concentrate Plus.
