Sponsored by: CARiD
Help - Hex screw fell inside the torque converter
Old Oct 28, 2015 | 11:14 PM
jt-hifi's Avatar
2001 ML320, 2010 S550, 2012 E350, 2015 C300 (All 4Matic vehicles)
My first post but I'm in desperate need of help.
I was doing a transmission oil change for my 2012 E350. As I tried to tighten the hex screw onto the torque converter, the screw fell inside the bell housing. I tried to search it with a lighted dentist mirror and a wire with no luck.
I'm going to buy an inspection camera with a flexible cord and lighted tomorrow and will try to use it along with the a flexible magnetic tool to pick it up.
Do you guys know if if there is an easy way to access the bottom of the bell housing?
I'm assessing what the negative impact will be leaving the screw inside. Will it come in contact with the flywheel when the car bounces while in motion?
I'd appreciate any help and suggestions you may have.
Thanks,
John
Old Oct 28, 2015 | 11:25 PM
PeterUbers's Avatar
Pm a member named shardul
He can help you
Old Oct 30, 2015 | 02:10 AM
jt-hifi's Avatar
Thanks. I was able to retrieve with the tiny magnetic pickup tool that comes with the Harbor Freight digital inspection camera. What a relief!
Old Oct 30, 2015 | 02:12 AM
vsix's Avatar
JBs C63 PP( wifes car ), Mc Laren Pxx(toy), 2013 Mustang GT 5.0 ( DD ), ML 6.3 ( winter DD )...
Jesus...glad you were able to get it out...maaan!
Old Oct 30, 2015 | 09:16 AM
PeterUbers's Avatar
Nice work!
Old Oct 30, 2015 | 06:53 PM
eshuber's Avatar
2012 E350
Don't feel alone - I have done a similar thing(but on a small block chevy. Had the distributor out(tells you how old I am) and dropped a nut inside the engine.
Taped a small magnet onto a flexible rod and fished it out!
Old Oct 30, 2015 | 06:58 PM
nycphotography's Avatar
'15 T&C & '14 SL63
I think anyone who works on things has had that moment of panic when we first realize we just eft up and will have to tear down the whole motor / house to get to the damn thing to fix it.
Then we eventually fish the thing out of the motor / drain and learn, hopefully, something about how important it is to control loose objects when working over bottomless pits ;-)
Glad you got it out!
Old Oct 30, 2015 | 09:19 PM
PeterUbers's Avatar
Magnets save yur a$$
Old Oct 31, 2015 | 06:08 AM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
This is what i use for times like that, a telescopic stick with a magnet at the end. You wouldnt believe how many times this thing has saved me from major headaches.
Help - Hex screw fell inside the torque converter-d2704b5f-02f6-4f08-b7d6-d1d4502a7e82_zpstqgput20.jpg
