Auto Feature
Old 12-01-2015, 09:26 PM
2014e350's Avatar
2014e350
Originally Posted by abbasali31
members with the negative responses: You bunch of morons, I didn't post my question with complete detail as I thought the members with the negative mindset would be smart enough to understand it, but I was wrong.
I set it to 80 degree as an example a few months ago while I was in Arizona where the outside temperature was above 100to to check the auto feature, but the inside temperature never went down to 80 after even 10 minutes.
Instead of bashing my thread, you morons would have asked for the explanation.
That still makes no sense; regardless dont waste your time on this forum; has more illiterates than others. Just set whatever temp you want and hit auto...dont try to think too much...things can overheat..lol
Old 12-02-2015, 08:57 AM
The G Man's Avatar
2019 E300
Thanks Key08! It was a typo and instead of typing 100, I wrote 80. Ya, It never cooled down so I will have it checked.
So you set your temp to a 100 deg.? Is that even possible
Hypothetically, lets just say you can set it to a 100 deg. and it is 100 deg. outside, the system in auto should blow 100 deg. air to maintain the set point of a 100 deg.
Old 12-02-2015, 09:21 AM
pamiboy's Avatar
E 350
I think the OP is either confused or cannot communicate properly what the problem is. Either way this thread has lost its direction. Would the OP start a new thread with an accurate description of the problem please. Thanks.
Quick Reply: Auto Feature
