Sponsored by: CARiD
Thoughts on K&N Air Filter for E350
Old Dec 21, 2015 | 03:43 AM
robin24's Avatar
BMW M6 Gran Coupe
Hey guys thinking about buying K&N air filter for my 2014 mercedes e350. Is there any benefits in buying this. Any noticable gain in hp or better gas milage?
Old Dec 21, 2015 | 07:35 AM
aquinob's Avatar
2010 E350, Sold 1998 C230
http://thegarage.jalopnik.com/here-a...ess-1744009588
Old Dec 21, 2015 | 10:54 AM
The G Man's Avatar
2019 E300
If you can pop in a air filter and gain HP and MPG, wouldn't you think Mercedes would have done it already?
Old Dec 22, 2015 | 08:16 AM
jawman's Avatar
2020 E63S, 2019 GLE 43,2017 GLS450,2012 E350
I put a K&N in my W212 for the simple reason it will stay with the vehicle for life plus I get a kick out of the service advisor coming to tell me the tech advises I change the air filter and then I get to suggest he looks at it first before making that recommendation. I say it has K&N then I get the well he was just going off the service records BS. Bottom line is no mileage or HP gain that is even remotely noticable but is very easy to clean re-oil and replace.
** note in my case it is only the filter element that was replaced and not a cold air induction system as noted in the "waste of money" shot in the above post*
Old Dec 22, 2015 | 08:58 AM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
I have used K&N filters in the past and while they may make your car sound better, if you like more noise, I don't think they improve performance or mileage. Also, you need to be careful when you oil them as you do not want the oil sucked into your intake. Bottom line, I don't use them anymore. It's not that expensive to drop in a new quality filter every 30K miles or so. Just MHO.
Old Dec 22, 2015 | 10:01 AM
The G Man's Avatar
2019 E300
Ironically, the cold air intake has shown in some dyno tests to increase HP. The problem with drop in K&N filter is that it lets in a lot dirt when new, it also age very fast and after a few months, it flow about the same amount of air or less air than the factory filter. If you over oil it, it can damage your MAP sensors.
Old Dec 22, 2015 | 06:27 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
Appologies to OP, no thread hijacking intented but since we're on the subject...
These are a couple of E250 Turbo engines. (i know most of you are not familiar with the small 250 engine so I have pics)
One with stock air filter set up and the other has K&N(?) pod modification.
Stock air filter set up...
Thoughts on K&N Air Filter for E350-abe77efd-d3ca-4ebd-b38a-dc9048058170_zpsoalks4c2.jpg
K&N(?) air filter mod...
Thoughts on K&N Air Filter for E350-2e8fff3a-888a-46a0-a940-9c28e7cc4b27_zpsngranojl.jpg
My questions are...
1. Any gain from the K&N(?) pod mod?
2. Wouldnt both warm and cold air instead of just cold air get inside as the pod does not have a cover of some sort?
3. Any long term bad effect for the engine with the mod?
