Sponsored by: CARiD
2011 E350 Bluetec Check Engine Light - Nox Sensor
Old Jan 10, 2016 | 07:24 AM
Aaplfan's Avatar
2011 E350 Bluetec
Bought a CPO 2011 E350 Bluetec with 46k miles a month ago ( my first MB). The day after I bought it the CEL came on. I took it into a local MB and the dealer replaced one of the Nox sensors under the CPO warranty.
The next day, the light came back on. Another trip to MB resulted in a sw upgrade, 25 mile road test, and another sensor replacement.
Just last night, the CEL turned on again. This is the 3rd time the light came on in my 4 weeks of ownership....looks like another trip back to MB. The Car has been in the shop longer than my garage.
I read about the AdBlue injectors being clogged and mentioned it to my service advisor but he claimed that was not the issue. Anyone else experience this many CEL /Nox sensor issues with their diesel? Any tips? Thanks!
Old Jan 10, 2016 | 12:36 PM
user 58362638's Avatar
I have a 2012 CPO E350 Bluetec (also my first MB) that's had 2 NoX sensors replaced, so you're not alone. I use top tier gas/diesel stations (i.e. Exxon, Chevron, etc.), so I dont think it's the fuel. Also when it rains a lot, I have the "check fuel filter" message pop on my cluster. I think it has something to do with the humidity. I'm almost at 40k miles, but I remember the first NoX sensor went out 35k, and then the second NoX sensor at 37k. Like you, my car has been in the shop more time than in my garage. I'm not bummed about it. On the contrary, I'm happy it's under warranty, those sensors are $800 a piece! Let me know if you have any other questions.
Greg
Old Jan 10, 2016 | 03:46 PM
Aaplfan's Avatar
2011 E350 Bluetec
Thanks Greg. Glad I'm not alone.
I declined the +2yr extended CPO warranty at the time of purchase. However, after taking my car in twice with < 1mo of ownership I purchased the 2yr ext warranty from a friend's contact at a different MB ( for $1400 less than what they tried to sell it to me at the time of purchase).
Will take my car back in to MB this week for visit #3....
Greg
Old Jan 28, 2016 | 01:14 PM
Aaplfan's Avatar
2011 E350 Bluetec
Update:
My vehicle spent 4 days at MB for further diagnostics and road tests. They replaced the last two NoX sensors and the Adblue Metering Valve. (all under the CPO Warranty). The CEL has not come back on since...even after driving 500+ miles. Fingers crossed that that was it....
Old Jan 28, 2016 | 01:29 PM
Great news that they fixed your MB! So, for clarification, is there a total of 3 or 4 NoX sensors? Thanks for the update, if I have any issues in the future, I can tell them to check the Ad Blue Metering valve.
Greg
Old Jan 28, 2016 | 02:17 PM
Aaplfan's Avatar
2011 E350 Bluetec
Greg, I was told by MB that there are four Nox sensors - two in the back and two in the front.
Besides your two sensors going out, have you had any other issues with your car?
Thanks!
Old Jan 28, 2016 | 02:29 PM
Thanks!
I've had the check fuel filter light up during rainy weather. I took it in once and they did not detect any water in the filter. I think the constant humidity is a factor when the filter should be checked.
I havent had any mechanical issues, however, there was a rattling in the rear deck. I think it's the sunshade but the dealer noted there were trim clips that were missing from the factory. They added those clips and for the most part the the noise is more temperature dependent. I'll continue to keep an eye....ummmm ear on it.
The prior owner has done the scheduled 10k services. The car had to get new tires, brakes, and battery to make it CPO ready. I had more cosmetic issues address (i.e. fading wood trim, worn front and trunk seals, a hump in the foam on the driver seat).
My MB (funny enough) came all the way from Hawaii to Texas, probably owned by a military member. I'm jealous, the car has traveled more than me! I had some oxidized trim replaced under warranty (i.e. the Star on the hood and the chrome window strip).
I'm coming up to my 40k service. They are going to replace the firewall liner under a TSB. I'm going to have them do the transmission service as required service. I'm including the differential and power steering flush just as a preventative measure.
Let me know if you have any questions.
Greg
