Sponsored by: CARiD
Air removal from rear air spring using STAR
Old Jan 17, 2016 | 12:18 PM
Chris_tA_4's Avatar
A4
Hey gang, does anyone know the steps using STAR to remove the air from the rear air spring?
Old Jan 18, 2016 | 11:44 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Go to "control units", "chassis", "airmatic", select which air bag you wish to work on, follow on-screen instructions.
Old Jan 18, 2016 | 06:22 PM
Chris_tA_4's Avatar
A4
That seems easy enough! have you done this before? I'm finally getting around to installing my rear adjustable control arms that have been sitting in my garage for a year now and I was told it's easier to install them with the air spring taken out.
Old Jan 19, 2016 | 10:33 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
I just performed this procedure this past weekend when I installed a new set of Arnott air bags in the rear of my '05. Before you pull the air bag, purchase two of these plastic clips.
http://www.pelicanparts.com/catalog/...pg5.htm#item13
Suspension Air Bag Clip (Rear Left Upper, Rear Right Upper); Part #: 211-328-00-58-M22
These clips hold the air bag to the car and the originals are going to break when you pull the air bag.
Also available from autohausaz.com.
http://www.autohausaz.com/search/pro...%20/%20Bellows
Old Jan 19, 2016 | 11:28 AM
RA72825's Avatar
This is the W212 forum and I don't think the newer bags have any clips like those on the older W211.
