Sponsored by: CARiD
2012+ E550 - What has actually broken?
Old Dec 26, 2017 | 09:41 PM
  #51
ecmexchange's Avatar
Former Vendor of MBWorld
na
Originally Posted by cocobeex
Just wondering, what is mileage on your vehicle ?
Mine had Cam Shaft position code popped once, I cleared the code and scanned with Xentry. It never showed up after clear codes.
But i am still wondering why would it show up.
Things like that make me worried the problem might pop up again. Hopefully it doesn't!
Old Dec 26, 2017 | 10:46 PM
  #52
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
if that poped again, i will replace cam position sensor first.
Old Dec 26, 2017 | 11:15 PM
  #53
na
This is a good idea. Might be good to have a few ideas at the back of the brain just in case.
Old Jan 9, 2018 | 03:36 PM
  #54
sleeperZ96BT's Avatar
2013 E550, 2014 GLK 350
I just had the radiator replaced at around 50k miles under CPO extended warranty - $1,500 or so job that was covered. Began leaking coolant.
Old Jan 10, 2018 | 10:17 PM
  #55
@dman's Avatar
2012 E550 (W212)
My 2012 E550 was purchased in 2015 with 26k miles, just off lease. I had it OEtuned at 35k miles and it's at 85k now. It's been nearly as trouble free as my Honda/Acuras in the past.
Aside from normal maintenance schedule items, I've replaced the front brake pads & rotors and the motor & transmission mounts were replaced under warranty to cure a persistent low frequency vibration occurring at light throttle just under 1500 rpm.
Good luck w/ your search & let us know what you pick up!
