Anyone use BlackVue 650 dashcam for 2016 E350 wagon?
First of all, I couldn't find the fuse box diagram in the car manual, so I had to Google it. Found one from MercedesMedic.com, but not sure if it's accurate.
I also uploaded the following picture:
- Fuse diagram from above
- Picture of the actual fuse from my E350
My questions:
1). Is the diagram (and the explanation listed here) correct? If not, where do I get the correct one?
I noticed that the diagram is missing information from the actual fuse box. I.e. there is a RED 10A fuse on the bottom right, but not shown in the diagram.
2). Looking at the actual fuse box, the area is marked with different color (I am NOT talking about the fuse color). There are yellow (bottom right), green (top), etc. Does this colored area mean anything?
3). Some of the fuse area is "locked", like the yellow one in the bottom right. I cannot remove a fuse and I am having a hard time removing that yellow lock. Does this mean I should not mess around with the fuses here? How do I remove the lock cover?
I've done this for may car stereo systems, radar detectors, etc.
I used a piggyback fuse connector that allows the original circuit fuse to be used while adding a secondary fused lead to the camera feed. It's not a big deal as the camera feed is very low amperage. I use these all the time as they provide a safe means of adding a circuit.
I selected the fuse that controls the trunk 12v power outlet as it is ignition controlled - I wanted the camera to only operate with ignition on. Look on your fuseblock legend and I believe it's one of the fuses in the yellow "caged" section. Have no idea why they decided to have those plastic cages but they simply unclip at the top and then swing open. The piggyback connector fits without any issues.
I did ensure that the 12v feed wire to the front was loomed and protected at all possible chafing locations.
Overall it was no big deal and everything works fine. If you are not comfortable with wiring then yes you should consider having someone do this. Also keep in mind that if you are using a hardwire kit (not sure what the Blackvue has), it is usually a transformer to convert down from 12v, the ones I have are 5v output. These can get quite warm in use so I avoid wrapping them in anything. I do secure with tiewraps but I try to leave some air space around them.
