Retrofitting Dynamic Active Multi-Contour seat to a 2014 E350
Thanks for the info, I found those settings in the engineering menu but to get the dynamic seats to work, the air pump, air reservoir and air lines have to be installed (not to mention the coding and wiring). I haven't done that yet.
As to the cooling feature, good call, I did install the updated dashboard buttons with the seat cooling option button and expected it to work. However, to get the cooling feature to work, I will have to hire someone who knows which pins to switch under the seat to the hook up to OE cable or whether a separate wire has to be installed. Haven't done that yet either. Just resetting the engineering menu won't get the seat fans to go on.
Just goes to say, it is usually cheaper to buy the model with features you want on it already than to try to add them after the fact.
Thank you very much!
PS. the car is Europe version.
I have an Air pump in my drive side there are not working - I will like to change that by my self, have anyone an idea of how to "open" the seat, and come in and change the air pump? Some kind of manual (Step by Step)
And where can you recommendate to buy the air pump?
Looking forward to hearing from you.
Please elaborate...
Obviously you installed the air pump and reservoir. Any programming needed?
I need to replace the driver seat in my 2008 W219 CLS63. The original seats are not DYNAMIC but the replacement one I am thinking of buying is DYNAMIC.
Do you know if the wiring harness and vacuum connections are the same? Would this be a simple swap or will it involve additional hardware/ software changes?
Original:
Replacement: (Donor car:2006 CLS55 AMG)
Original:
Dynamic seats or massage seats have a separate air pump to run them. You will need all those components. At least that is my understanding. My GL550 was purchased certified and the seat adjustments from the screen were not working; massage, lumbar, bolster. The dealer said it was the pump for the seats, but the air suspension worked fine.
Since the air pump and air reservoir have not yet been installed, I was not able to confirm that the dynamic functions worked. But, w/ the dynamic seat features on, the seating heating elements worked properly (heating up the rear of my butt as well as everything else, whereas before changing these entries it would only heat up my back and the sides of my butt). Sadly, the seat cooling button does not light up blue, but when I press the button (how many times varies because I can't tell what setting it was on originally), I can feel the center back of my butt cool off and seemingly, by pressing the button a variable number of times again, the cooling feature disappears.
Does this mean that once I get the air pump and reservoir installed, the seat should work properly, or is further, dealer only or star only, coding still necessary?
Also could someone please post the WIS instructions to install/replace the air pump and air reservoir that fill the air bladders in the dynamic seats. Here are the vin's for a couple of W212 E's with these parts installed: for a 2014 E63, WDDHH7GB0EA977335; for a 2014 E550, WDDKK7DF8EF244564. The WIS instructions to install/replace the split-folding rear seats for these vehicles would also be appreciated.
I have a Multicontour seat, and it is Dynamic, and give massage. Meaning I activate the dynamic function and massage, and the seat tilts on a hard curve at the same I am getting a massage.
I've searched this forum and Goggle and have not found a DIY guide or any kind of a detailed discussion on how to retrofit a dynamic active multi-contour driver's seat to a 2014 E350 besides call Steve at MBenzNL. I hope you guys can chime in and help, specifically Steve, Chris the Swede and Nuru who seem to know how to do these things.
I have a dynamic active multi-contour driver's seat and split-folding rear seats from a 2010 W212 E63 that I'd like to install in my 2014 W212 E350 that did not come with these available options.
I also purchased the airpump and compressed air reservoir that fit behind the driver's side rear quarter panel in the trunk which I believe are necessary to operate the dynamic side air bolsters on the multi-contour driver's seat. I also purchased the switch bank (which fits under the the command button and above the climatronic switches) that has, besides the hazard button, buttons to turn the seat heating and cooling on and off.
Physically, I'm pretty sure I can install these seats and the new switch bank without much trouble but, what I do not understand how to do is hook up the air pump, air reservoir and switch panel to make the front dynamic active multi-contour driver's seat work properly and to hookup the sensors in the split-folding rear seat that tell the car when the rear seat is up or down (there was a brief post on this, but it is not complete).
Does anyone here know or have the WIS or EPC sheets with pictures that show how these parts are supposed to fit together and what is necessary to make them work?
I'd really appreciate any help. I've attached pictures of the seat, pump and switches. I can photograph the reservoir later if necessary.
hey buddy, do you have a part number for the control switch you purchased
