Sponsored by: CARiD
2010 E350 bluetooth
Old Mar 24, 2016 | 10:51 PM
Must2fa's Avatar
2010 E350
2010 E350 bluetooth
Hello! I just bought a Preowned 2010 E350. I was able to pair my phone to the Bluetooth to make and receive calls, However I cannot connect my phone to the Bluetooth Audio feature. How can I stream music from my phone via Bluetooth? I tried to connect with Bluetooth audio, input the pin and then it says unable to connect. I have the Harmon Kardon system.
Old Mar 25, 2016 | 08:02 AM
blegthbloo's Avatar
2013 E550 4Matic
https://mbworld.org/forums/e-class-w...ml#post5275268
Go into the engineering menu, find the option for BT Audio, and enable it.
Old Mar 25, 2016 | 08:01 PM
Must2fa's Avatar
2010 E350
It's already turned on. I am receiving calls via Bluetooth.
Old Mar 25, 2016 | 08:03 PM
Must2fa's Avatar
2010 E350
This is the message I get when I try to connect to Bluetooth Audio.
Old Mar 28, 2016 | 08:43 AM
blegthbloo's Avatar
2013 E550 4Matic
I think there was a separate option for BT streaming audio when I looked at mine. I was able to do BT phone calls, but went to the engineering menu and saw that another BT option was set to "disabled" so I enabled it and was able to stream from there.
Old Apr 17, 2016 | 10:54 AM
osugrad2x's Avatar
2010 E350
Did this get solved yet? I am able to make calls as well. I went into EM and turned on "BT Audio" and i get the same screen notice as Must2fa for my iphone6.
Old Apr 17, 2016 | 11:27 AM
BENZINO350's Avatar
2010 Mercedes Benz E350 sport 4matic
Hi I have a 10 e350 also.. I tried enabling bt audio in the engineering menu and it still didn't change a thing! Please help I would love to have Bluetooth audio in my Benz
Old Apr 17, 2016 | 11:36 AM
osugrad2x's Avatar
2010 E350
I did purchase an
adapter from amazon adapter from amazon
that works great, but only for Apple Music.
Basically if you're using AM then its fantastic. But any other app you get sound only and no controls.
Old Apr 17, 2016 | 02:16 PM
BENZINO350's Avatar
Originally Posted by osugrad2x
I did purchase an adapter from amazon that works great, but only for Apple Music.
Besides Apple Music does it work for your regular music from iTunes library .
Old Apr 17, 2016 | 03:11 PM
osugrad2x's Avatar
2010 E350
Yes, it'll play and show song info and you can control all aspects when your inside the iTunes/Music app.
Old Apr 17, 2016 | 03:30 PM
osugrad2x's Avatar
2010 E350
Correction, Amazon Prime Music plays with no info, Google Play Music plays and can Ff and Rew but no info. I dont use spotify or pandora so i cant comment on those.
The unit can remember multiple phones, it will autoconnect to the last used device.
Old Apr 17, 2016 | 03:37 PM
osugrad2x's Avatar
2010 E350
I'm using an iPhone 6+ on iOS 9.3.1 if that matters.
Old Apr 18, 2016 | 01:19 PM
sentralfyr's Avatar
2015 S205 AMG
Try to connect as an "External" device.
I have to connect as an "external" device everytime i want to stream from my iphone
i got a 2011 E class with comand NTG4
On the screen where you see your iphone, got to "options" and try to connect as an External device from there.
Old Apr 22, 2016 | 01:41 PM
Gunareble's Avatar
Mercedes E350
I have a 2010 e350 and i ran into the same issue.
Option 1,
I went through the EM and was able to sync my phone as a BT Audio device. I ran into a problem where everytime i shut the car off, i had to go through the pairing process (authorize/unauthorize device, then pair the device) which became a bit too much for me to handle.
Solution: Dealership can/would upgrade the comand(sp?) software to allow my iPhone to connect/reconnect automatically. Free under warranty or costs about 400USD (2hrs of labor) if its out of warranty. or maybe free if you knew someone at the dealership or whatever.
second option (which i took/osugrad2x's recommendation plus a little bit of what i found out today)
I bought the adapter from amazon. Here are a few things that I found so far,
Its glitchy (wont mention everything TMI)
You will get the title of the track every once in a while 40/60 chance (netflix, youtube, pandora, spotify, music/itunes app) to me that wasn't that much of a big deal because I was worried about the audio and being able to sync my phone automatically after shutting the car off/on.
sometimes the titles are mixed up but controls still work. sometimes it just freezes (audio still plays) and you'll have to use your device (in this case iphone) to skip and stuff.
What i found out today( not sure why it took me this long),
You can sync your phone to both the Tuneair bluetooth adapter (for audio) and your car audio (for handsfree) and it will work just fine.
screenshot:
If you ask me the second option was way cheaper and much less of a headache to work with.
Old Apr 22, 2016 | 03:54 PM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
On a side note. Nice "Album" playlist right there
Old Apr 22, 2016 | 04:08 PM
osugrad2x's Avatar
2010 E350
Yeah I should've mentioned the dual bt option.
Yes it gets glitchy once you leave the music app and play music from other apps.
For the auto connect with both. I took one of the Amazon reviews notes. Turn the Benz bt option off. Connect the adaptor and connect your phone to it, it will connect to audio only. Now turn car bt back on and pair your phone.
From this point it should connect every time you get near the car to the adaptor and then the car as a phone when you turn car on. I like this cause the music starts playing when you get in as if you left the radio on, no waiting or button pressing.
I eventually turned the bt audio back off in EM because my phone stopped connecting as phone. Not sure what happened so I just went back to what works. The wife is happy as well.
Side note. I found a hardware option in EM to turn bt transceiver on, which was off by default. But turning it on didn't do anything but cause more erratic behavior.
Old Apr 25, 2016 | 01:54 PM
xheamgbenz's Avatar
W203 C32 AMG...W221 S63...SOLD...W212 E63 CURRENT
It only work with a android it would not work with the iPhone
