Vacation - Battery Maintainer
http://www.ebay.com.au/itm/161539198...%3AMEBIDX%3AIT
the website you attached does not have Australia but this ebay site says theyre an authorized dealer and comes with 5 yr warranty. if you reckon itll work with our cars ill give it a go.
ill just use it to charge the battery when cars are not in use, mainly for the 63. another thing is I installed dashcam on our cars so just in case battery dies on me when at home. also, would this help prolong the battery life? thanks!
if you can look into the last ebay link i posted. would that be enough to do the job at a reasonable time? but most importantly, wouldnt do any damage on my electricals. thanks guys!
and forget about it. Other than the car losing all of its air after 6 weeks of sitting, it starts right up....plus I think I paid about 50 bucks for it
OP, didnt mean to hijack your thread but i guess all the info added on here will be useful for others as well to have more options.
I am going on an extended vacation and do not want my car battery dead when I return for obvious reasons. I believe I am looking for a device that will maintain the battery and give it a boost when it drops charge. Is this called a battery maintainer? Does anyone currently use one for their E550? I believe I read good reviews on CTEK maintainers.
Any links to good ones? And what is the difference between maintainers, tenders, and trickle chargers?
And why is this one so cheap? Lol
http://m.harborfreight.com/automatic...ger-42292.html
Also, how can I test that it's really working before I leave on vacation? Is there a way?
Thanks!
How long is your vacation? I have left my car at an airport for 3 weeks numerous times and never had an issue starting it.
The battery should be about 100 Ah capacity. Parked car should not take more than 0.02A current. Half of battery capacity would be consumed in about 2500 hours, i.e. about 100 days. If the pull was 0.05 A (high pull) it would take 1000 hours (40 days).
So, how long vacation do you plan to have?
i ended up buying the CTEK MXS 3.8, i was told that its more than i needed to do the job. thanks again guys!
would it be ok to use the 3.8 everyday? i dont use the C63 often so is it ok to leave it plugged in even without any signs of battery wear? also, my wifes coupes dashcam does not last as long as my sedan when in park mode, i figure since she only drive about 10-15mins one way, the battery does not have enough time to charge, is it ok to plug the ctek at night then unplug it in the morning before she leaves? no signs of battery wear either, i just think it might help with the dashcam to stay on longer.
Each time I connect my charger it takes about 8-10 hours to reach full charge. It only take about 4 hours on my wife's car. No need to worry about disconnecting it until you're ready to use the car whether that be a day or weeks later. In trickle mode, the volts and amps are low and not putting much stress on the battery.
Im just surprised as to how small the battery is. Seems OEM with the MB logo but still...
). My battery takes up all the space that you see to the left of yours. By the way, you can use the brass colored post on the right side for the negative. That way you don't have to take off the air intake cowl. No need to connect directly to battery then.If I connect mine in the evening it is usually done by noon the next day thanks to the low state of charge the alternator leaves the battery in.
MXS 3.8:
Rated Voltage AC 220–240VAC, 50–60Hz
Charging voltage SMALL, NORMAL: 14.4V, COLD/AGM: 14.7V
Min battery voltage 2.0V
Charging current 3,8A max
Charger type 7 step, fully automatic charging cycle
Battery types All types of 12V lead-acid batteries (WET, MF, Ca/Ca, AGM and GEL)
Battery capacity 1.2–80Ah up to 130Ah for maintenance
CTEK 3300:
Input voltage AC 85-125VAC, 50-60Hz
Charging voltage 14.4V /14.7V
Charging current 0.8/3.3A max
Type of charger 4 step, fully automatic switch mode with pulse maintenance
Type of batteries 12V lead-acid batteries (Wet, MF, AGM, GEL and Ca) Battery capacity 1.2-120Ah
CTEK 4.3:
Charging voltage 14.4 / 14.7 / 15.8 V
Charging current Max 4.3 A
Type of charger 8 step, fully automatic charging cycle
Type of battery 12V lead-acid batteries Battery capacity 1.2 - 110 Ah, up to 160 Ah for maintenance
MXS 3.8:
CTEK 3300:
CTEK 4.3:
g4benz, yeah Fisch is right, i think the model just varies from location.
Many years back a family member fell ill and her car was not touched for a year. I finally got to the car, went in, and it started right up. 3 weeks is cake
