Sponsored by: CARiD
How important is the Tyre Load Rating?
Old May 17, 2016 | 04:48 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
good day! just how important is the tyre load rating (not speed) with a daily driven car like the E class? i spoke to a few tyre guys and some say I should stick (or go over) what that manufacturer states but others say its ok to go under.
a lot of tyre brands dont make the required load rating for my sedan in 20" wheels. appreciate any input. cheers!
Old May 17, 2016 | 08:45 PM
pamiboy's Avatar
E 350
An underrated tire will bend excessively at the sidewalls during driving on uneven roads. That may contribute to premature failure of tire.
Old May 17, 2016 | 08:53 PM
beejAMG's Avatar
my sedan says 95 which is about 690kg/tyre. would it be a big factor if i go 90 which is 600 kg/tyre?
im a bit confused as ive spoken to a few tyre guys and half say its important, not to mention legal, and some say its not as important and my sedan is already illegal in a way as im running 20s already.
Old May 17, 2016 | 11:15 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
Opinions may vary but I personally would not go below the load rating. Yeah you may think that is for only when the seats and cargo are full. But you have to think of the load placed on individual tires while cornering too. I wouldn't risk it but many say it is fine if the lower rating covers the fully loaded weight.
Old May 17, 2016 | 11:29 PM
beejAMG's Avatar
atm, i have cheap chinese on my sedan. 245/30/20 95W, load rating as required, no complains whatsover until i had a low tyre pressure warning on my dash.
came in and had it checked, apparently front tyres are separated and i need a pair. fair enough. problem is with my tyre size, only low quality chinese makes them with the 95 and up load rating otherwise i have to go with high end brand and would cost more than what i want to spend.
heres my dilemma, i can put a "better" quality chinese (better than whats on now apparently) tyres for less than $150 with correct load rating but i may end up with the same situation soon. or i can have a middle class brand like hankook, conti or kuhmo for about 250 but with lower load rating.
im thinking, better brand with lower rating or cheap brand with correct rating.
Old May 17, 2016 | 11:47 PM
thefisch's Avatar
Top Answer: 1
My tires last me at least 6 years so I tend to buy Michelin with proper specs. Came out to about $200 per tire installed here in FL. Sounds like your options are limited though and more expensive there. What does the MB dealer offer as options and can you find those somewhere else for less?
If you're not planning on keeping the car, then go with the off brand and hope the last pair of bad tires was a fluke. If not, I would pay the price to not worry about them.
Old May 18, 2016 | 12:58 AM
beejAMG's Avatar
I have the other car in for service so i can ask them later when i pick it up from the dealer but im pretty sure it will cost me an arm and a leg. I love michelin but for 20s with the correct size and load rating can be as high as 600 each. And i reckon for my E250 might be a bit much. So im leaning towards hankook sport IV with 90W rating.
Edit: good point when you mentioned about keeping the car for long or not. Right now, i enjoy it as a daily and with occasional long drives and when i get tired of it i tend to use the other cars so i might have it for a lil longer.
Old May 18, 2016 | 08:43 AM
The G Man's Avatar
2019 E300
Tire load rating is how much the sidewalls are design to support, if you drive on under rated tires, you will risk premature tire failure or in a worst case scenario, a tire blowout. Ask the tire dealers who said it was ok to drive on under rated tire to put it in writing, I bet none of them would do it. A couple of areas to consider are how often do you drive your car fully loaded, how fast do you drive on the highway or how often do you drive aggressively. Over-inflating the tires a bit can help, but your threads will not wear evenly and tire traction will be compromised.
Old May 18, 2016 | 04:47 PM
beejAMG's Avatar
youre absolutely correct. nobody will put that in writing, matter of fact they will have me sign a waiver if i want to put under rated tyres.
but with my situation, its like being stuck between a rock and a hard place. dont want to spend too much with this car. daily driven conservatively (cant be too aggressive with this engine ) long drives here and there doing occasional 150k/hr. i inflate my tyres at 40psi.
so its pretty much this...better brand with lower rating or cheap brand with proper rating. correct tyre size and load rating for my car/wheel will set me back north of $600/tyre.
Old May 19, 2016 | 12:32 PM
The G Man's Avatar
2019 E300
Personally, I would rather have a name brand tires that are a bit under rated than a economy tire with the right rating. The sidewall on the name brand tire will probably have better sidewall construction.
Old May 19, 2016 | 04:46 PM
beejAMG's Avatar
thats what im thinking and im hoping thats the case.
anyways, i ended up with Hankooks with 90W. so much quieter now and rides better, i reckon. will update this thread after a few months and see. thanks for all the help guys! i really appreciate it.
