DIY - replace rear air springs
Rating: Thread Rating: 4 votes, 5.00 average.
Old 06-24-2024, 09:06 PM
  #176
Raj1471's Avatar
2011 Mercedes E350 4Matic Wagon
Originally Posted by retna7
Does anyone have a method for securing the rubber boot at the bottom of the air strut?
The cover pops out of the perch at the bottom every time I get the strut aligned at the top.
Looks like the boot is supposed to lock into the perch.
The weight of the vehicle when you finally assemble and have wheels on the ground will keep the lower boot against the control arm.
retna7 (06-24-2024)
Old 06-24-2024, 09:16 PM
  #177
Left Coast Geek's Avatar
Received 1,283 Likes on 878 Posts
2016 E350 4Matic wagon, 2019 Ford Expedition 4x4
if the vehicle is up in the air with its wheels at full extension, that might be causing this. put a jack under the wheel and raise it an inch or so and install the air spring.
retna7 (06-24-2024)
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: DIY - replace rear air springs
