Sponsored by: CARiD
2014 e 350
Old Jun 14, 2024 | 04:41 PM
fahadscores's Avatar
2014 e350
2014 e 350
Front drive shaft going from transfer case to front differential is broke.
does the front differential or axles or wheel bearing goes bad with it?
Old Jun 14, 2024 | 05:03 PM
JettaRed's Avatar
Veteran: Army
Are you asking if those other things were damaged when the axle broke? You need to have a mechanic inspect your car and answer that question.
Old Jun 14, 2024 | 05:15 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
short straw
When that shaft brakes off it's extensive damage with a T.
Post some pictures for a more realistic accounting.
Old Jun 14, 2024 | 09:29 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
if you vehicle is not missing a part of the tranny casing, or leaking oil everwhere consider yourself lucky.
get an estimate and decide from there: minimum is a brand new shaft plus labor
Old Jun 21, 2024 | 09:48 PM
2014 e350
My front drive propller shaft was broken on 2014 e350 my mechanic changed it while changing my mechanic took the transmission oil line he took it out to get to the shaft then he put it back together he lost 10oz of transmission fluid (oil) do i need to add it in the transmission?
also my front passenger side axle rubber boot is leaking like i see oil around it DO i need to change that ?
when my car is going above 60 to 80 i hear grinding noise why ?
please advice thanks
Old Jun 24, 2024 | 11:07 PM
multiple issues
What your car need falls under MAINTENANCE. It's not just the brake noises and the amazing gear shifts.
So you can learn about it or drop off your car at the nearest MB specialist.
Get your steering rack campaign status checked.
(Budget 1 to $3k including wiper refills)
