How Replace W212 Driver's side directional signal bulb?
2010 M-B E350
The Owner's Manual says to remove one screw (bolt) & the washer tank will swing aside. Really? Removal of that one bolt gives about 1/4" movement to the tank. Hardly enough to gain full access.
While both high & low beam lamp backs are accessable, and removable, there is nothing visible with a mirror and flashlight that resembles what the manual shows is the directional bulb housing.
Any help will be appreciated.
Thank you.
Thank you.
