Front brake pads and Rotors -E550 2011
Do those pads from Autozone come with a new wear sensor, Arrie? I need to replace my fronts and my check pad wear warning notice is active.
KEY08 (08-17-2016)
Okay, I now see that Autozone also sells the pad sensor, so I will just buy one. I see you have the brown leather in that photo. Same combo I have and I love that old school color with the white.
2010 e550 p2
yea i luv this combo too , ppl who sit in always compliment.
#33
I have no issue with vibration under braking, so I would like to get some more miles on my rotors. Once I yank the wheels and check the wear that may change. Then I will follow your lead. The pads are dirt cheap and I will just be doing the front.
#35
2011 E550
I had no issues when I bought my E550 CPO until the dealer said I needed new brakes. They quoted me a price and for the brakes and rotors it was $40 more than the non dealer price so I went with them. After about 4,000 miles I started getting a little vibration that was noticeable if I tapped the brakes on the highway. Over the next 2,000 miles the vibration got worse to the point it was getting scary.
I took the car back to the dealer and they checked the rotors and said they were defective and replaced pads and rotors for free. 10,000 miles later they are perfect. I wonder if they just have quality issues with the E550 rotors.
#37
Sorry late on this. House flooding issues...
The pads do not come with the sensors as you already have discovered. I changed mine before the warning was triggered so I used the sensors from the old pads. Just had to open up the hole in the new pad for the sensor to fit.
KEY08 (08-21-2016)
#38
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/image_581de1c7206885056347f0d1ac92798db03f2e2a.jpeg)
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/image_18df39f72abed6854da38ad9886dd35f8fe883af.jpeg)
So, I decided to continue with the OEM pads( which are Carrying the Akebono marking). I will switch over pads when I do the rotor replacement. The biggest issue with any work in the wheel well is getting the damn wheel off. Lol. I always have to use a breaker bar on the bolts and bang the crap out of the wheel to bust it lose. After that everything is easy. Here are a couple photos of the right front pad with the sensor and the thickness at which the "check pad wear" warning is activated.
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/image_8effb51253a9b11c76b77c2239f15ce5a69c4572.jpeg)
#40
Yes, all OEM at the moment, and the pads are clearly marked AKEBONO. MB pads are outsourced. These are great pads and my rotors have no lippage, so I will run these now until I have to switch out. The pads were $110.
Drove 400 miles over the weekend and new pads are great. Bad news is, the check pad warning went off on the rears now just yesterday. I knew they were getting close, so now I get to do those also. haha
