Passenger windows won't roll down and gunk/goo/slime in spare tire compartment
Wife left windows on her side open, and rain got in over a month ago. I did check and it was wet but not flooded and after letting everything dry, everything worked with no issues. But can what happen last month finally affect it now?
I am also finding sticky goo in the spare wheel compartment on the driver side. Passenger side is clean. I was thinking the heat melt some rubber or sealant there but the other side has nothing happening. I cleaned it up a bit, it looked much worse before.
Since your 2014 should still be under warranty, I would just take it in. Don't worry about the water from the rain. As you said, it worked fine after it dried but only recently started to not work.
Also show them the goo. I would think that is grease running but I don't know why that much would run.
