Sponsored by: CARiD
Transmission fluid flush
Old Aug 3, 2016 | 07:25 PM
edstein's Avatar
2102 E350
My dealer wanted $765 to do a fluid flush on the transmission on my 2012 E350 Sport. I did not have it done as it seems too much. What should it cost?
Old Aug 3, 2016 | 09:58 PM
jylee's Avatar
14 E350; 12 Camaro; 07 Range Rocer; 06 Dodge Ram
Ask the dealer to change the filter and fluid, not flush. If the price is too high, do a search, it is not hard to do it job yourself.
Old Aug 3, 2016 | 10:07 PM
RA72825's Avatar
$350 for 40K mile transmission service at my indy.
Old Aug 3, 2016 | 10:49 PM
polmati's Avatar
2010 E350 4M
I had a flush done at local Indy 6 months ago (12 quarts of fluid) for 225. The flush is a valid procedure invoked following transmission maintenance. The general flush seems easier than drain and filter replacement. Next time I think I will request the standard drain, filter change, and refill. In any event $700 plus is outrageous.
Old Aug 6, 2016 | 05:06 PM
blackbullit's Avatar
2013 ML350, 2019 S560
I had flush done on my E320 & it ruptured the seals, destroying control module & costing me $6000 to fix. These transmissions were made to drain not flush with pressure. Be careful. My Indy did it right on my next E for $400.
Old Aug 6, 2016 | 07:12 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
My E63 cost about 450.00 for a drain and refill. Flush is not necessary. Drain, refill and replace filter every 40,000 miles.
Old Aug 6, 2016 | 09:49 PM
edstein's Avatar
2102 E350
Thanks for the answers on the trans fluid and flush
I found a place that I have dealt with in the past. Hixson transmission in Hixson TN that will do it for $215.
