Sponsored by: CARiD
Changing the spark plugs 2014 E350
Old Sep 17, 2016 | 07:42 PM
ElisTwoCents's Avatar
2015 E-Class
Not being mean or anything as I certainly wouldn't want to pay $700+ for plugs but if unable to pull engine cover then maybe one shouldn't attempt any mechanical service
Old Sep 20, 2016 | 12:31 AM
OkieBikerDude's Avatar
E 350
I can understand the desire to reuse the engine cover so caution can save some $$$. I changed my plugs at 60K and they didn't look too bad so I plan to go to 120K with the new ones.
A little freebie I'll throw in: When starting the new plugs place a 4" - 6" piece of vacuum hose on the plug to reduce the danger of "cross-treading". Once the plug is installed and prior to torquing just pull the hose off.
OBD
Old Sep 20, 2016 | 07:31 PM
BBB78's Avatar
W212
$700 for a plug change in ridiculous. Did that include anything else?
Are all MB services this expensive?
Old Dec 29, 2016 | 05:47 PM
Diamond White W212's Avatar
2022 GLE 450;
After reading the service bulletin linked above and seeing that the intake manifold needs to be removed on 2012 and newer E350s, I now see why it's so expensive. A local indy mechanic quoted me $600 and told me the Star manual describes it as a 5 hour process. The dealer also told me $712 and said 4-5 hours without looking at the book.
The earlier E350 didn't require removing the intake manifold and it would be just as easy as the other dozens of cars I've changed plugs on. I plan to wait till 70,000 miles and have them check for carbon deposits on the intake valves at the same time while I could possibly get those cleaned under warranty at the same time.
Old Dec 30, 2016 | 04:48 AM
Peachy's Avatar
2010 E550
So glad I have the old E550, took me less than half an hour to do my spark plugs.
Old Dec 31, 2016 | 08:33 PM
Devoir's Avatar
E350
2013 E350 W212 Engine 276.952 Spark Plug removal at 60K service interval
I read #13 posted by Konigstiger This PDF was a great guide....
I have removed #1 Front Engine Cover
I have removed #2 Air filter housing.
#3 Intake Manifold Can anyone post how they removed the intake Manifold...
With the #2 Air filter housing removed I was able to pull the T1/1 ignition coil. My standard Deep well 5/8" socket will not go down into the spark plug well inside the head. What brand or where did you purchase the correct Spark Plug socket?
Looking in the EPC site they call for a tool W 278 589 00 09 00 Spark Plug Wrench. I'm not finding it online to purchase..
Spark Plugs. in this E350 engine 276 with 3.5 Liter I haven't seen anyone posting much about what type of spark plug they are using or are considering. My research shows Denso 3495
Question for Konigstiger .... are you accessing the PDF inside the EPC site? I paid for a subscription but I can't see where those PDF's are located... I was hoping to look for additional details.
Devoir
Old Jan 1, 2017 | 10:35 AM
  #32
konigstiger's Avatar
'71 Pinto
Manifold, see attachment.
Wrench, drop W search 278589000900
Spark plug OEM part 0041598103
EPS covers parts only, owners can access STAR – WIS by subscribing (24 hours $60) here: https://www.startekinfo.com/StarTek/ allows you to download unlimited current VIN specific instructions covering every aspect of vehicle.
File Type: pdf
Old Jan 1, 2017 | 11:23 AM
  #33
aquinob's Avatar
2010 E350, Sold 1998 C230
Wow, you have to remove the manifold to do plugs? Very happy to have a 2010 in that case. I've done lots of maintenance over the years on cars and everything else, but I'd be a little dicey on pulling the manifold on one of these beasts. Do something wrong and you may end up with a vacuum leak or some other issue and you may have to repeat the process. As cheap as I am, this is probably one I'd pay to have someone else do.
I wonder if other direct injection engines make you remove the manifold to access the plugs? To me, this is poor engineering.
Old Jan 1, 2017 | 12:15 PM
  #34
Devoir's Avatar
E350
Konigstiger
Many thanks for you assistance and direction removing the intake .......
Spark Plug socket update...... With a flashlight and a micrometer I measured the spark plug well it is approx .810" in diameter. After looking closely I noticed the spark plug wasn't the standard 6 sided hexagonal shape. Thus none of my attempts using a 6 point socket worked.
I have just discovered that my 12 point 9/16" deep well socket will slide down into the well and fit over the spark plug. However it appears to be loose or not a snug fit...... I'm now searching for a 14mm socket with 12 points is such an animal exists....
My neighbor is an Indy mechanic..... I'll see if he has such tool in the garage....
I love a challenge and especially working on cars.....
Old May 17, 2017 | 03:40 PM
  #35
ijain314's Avatar
2013 E350 Sedan
Originally Posted by Devoir
Konigstiger
How did it go? I have a 2013 E350 too and thinking about doing the spark plugs...
Old May 17, 2017 | 11:13 PM
  #36
Devoir's Avatar
E350
Let's just say I'll post a How to do it..... round 1 the dealer sold me the wrong plugs and the engine didn't like them so I put the old ones back in .... I'm waiting a a replacement set... I have a really cool installation guide with pictures.....
Old May 18, 2017 | 05:06 AM
  #37
ijain314's Avatar
2013 E350 Sedan
sounds good! I look forward to using your guide. Haha.
Old May 18, 2017 | 10:20 AM
  #38
ijain314's Avatar
2013 E350 Sedan
So I just talked to the Benz Dealership. They quoted me $384 before the $75 off coupon to do the plugs on a 2013 W212. Im tempted to go this route seeing how much work is involved (Manifold removal). Also my car is still under CPO warranty so idk if I want to give them a reason to say "i screwed it up"
Is this a good price?
Old May 18, 2017 | 10:41 AM
  #39
blegthbloo's Avatar
2013 E550 4Matic
I paid 300ish labor to have mine installed... I'd say with the coupon you have a good deal. And I have 2 more plugs to replace than you do.
Old May 18, 2017 | 11:53 AM
  #40
ijain314's Avatar
2013 E350 Sedan
Well I am at the dealership right now getting the plugs done. They just told me that they incorrectly quoted me....It should have been $682. I expected that...seeing how thats in line with what other forum members are being quoted.
Seeing how they made the mistake they said they would honor the price of $380.... (parts and labor)
Old May 18, 2017 | 01:42 PM
  #41
blegthbloo's Avatar
2013 E550 4Matic
I brought the parts to them, which came out to about $80 from ebay I think... OEM parts in OEM packaging. I guess yours would be $60, or you could have 2 spares laying around, which wouldn't hurt. So all in all, I was in about $380 as well... still a good deal lol
Old May 18, 2017 | 01:56 PM
  #42
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
sounds good to me. My local dealer wanted $600 for the plugs.
Old Jun 26, 2017 | 03:39 PM
  #43
n263nd's Avatar
2012 R350
What is the MB-recommended torque for the spark plugs on the M276 engine?
Old Jun 26, 2017 | 03:58 PM
  #44
'71 Pinto
See attachments.
File Type: pdf
Old Jun 26, 2017 | 04:09 PM
  #45
n263nd's Avatar
2012 R350
See attachments.
Thank you, but I can't seem to find any torque information on that attachment (?).
Old Jun 26, 2017 | 04:22 PM
  #46
'71 Pinto
Lower section, see attachment ...
Old Jun 26, 2017 | 04:31 PM
  #47
n263nd's Avatar
2012 R350
Thank you very much; I totally missed it at first...
Old Jun 27, 2017 | 12:03 PM
  #48
lakepop's Avatar
2011 E350, 2015 E350 Sport
Looks pretty straight forward to me.....save some $$$$
Old Jun 27, 2017 | 02:51 PM
  #49
ktr's Avatar
ktr
'12 E350 BlueTEC Sport
Different engine in the 2012+ model years.
Old Jan 1, 2018 | 03:59 PM
  #50
SeaRay45DB's Avatar
2008 ML550 2013 E350 4Matic Sport
Not very good advice.
Originally Posted by jylee
If the car runs good, I will wait. It is not a big deal to run the plugs longer than recommended.
Never go over the time stamp. These are aluminum blocks. The plugs will seize.
