Tire pressure message
Is this telling me I should take some action to correct the tire pressure or just letting me know on its own that all is good?
Like Key suggested, if you are happy with the pressure you have, then just reset the reference values. Keep in mind that the values are set for each tire individually based on the current reading when you reset. The car doesn't know what are correct values are, only the last saved references value so be sure to correct pressure first. To go to that, I think you go to the Serv>Tire Pressure where you can see the readings (not that warning) and then press down arrow and OK to reset like Key said.
I did notice the E550 standard pressures are higher than the E350 I used to have (e.g. ~38f vs ~35f on the 350) and I always kept them around 34 on the 350, which the 550 doesn't like (even after resetting the TPMS), but after resetting it a few times it seems to "learn" what I like and doesn't alert anymore.
