Command control knob
Where can I buy a command control knob unit for my 2011 E350 Sedan. I need to replace mine with the 4 year failure issue. Have searched but am unable to locate one.
Yes....have read those post and have the video to install......having problems finding one to fit my puppy. Have checked ebay and a number of parts dealers other than my MB dealer. I captured what I thought was the part number off the install video.......did not work.
Anyone have the part number or a part source ?
2010 e550 p2
2048700679 (supposedly the updated and more reliable) or 2048709558 (older version)
its interchangeable with early models of c class.
or if you not sure pry off the square looking trim around the command know and you will see the top of the controller which will have part number right on top.
Command controll knob
What I got off the install video( which was for a 2011 E350)was part # 2128702851........that # does not produce results at any of the parts sources I have tried. I'll try your #s
Thank for your responses
I would try to fix it. Cheapest is with glue and toothpicks. For under $50 I think there is a part available that stabilizes the shaft. Otherwise I think is over $200. Same amount of work to replace or fix.
OK....looks like I found the part to match my VIN. Its 212 870 28 51 . Will order it on monday.......$270 with tax & shipping.....way better than the $650 dealer wanted. I will install it.
Thanks for the inputs
2010 e550 p2
i could put 270 to use on smth else.. but if you aint trying to mess with it... and dont care about money thats wassup lol
its gonna take u like 5 min to replace it. thanks for sharing part number ppl will find it useful
Received 1,499 Likes
http://www.mbdirectparts.com/oe-merc...enz/2128702851
Also if you search on ebay with that part number, you might be able to find a used one.
lakepop (10-10-2016)
Command Control Knob
OK......Ordered the part today....total was $202 with tax/shipping. I am most happy with the cost. Note that the issue was NOT a broken shaft on knob but something else......so for me a repair was not an option. The forums have been most helpful and I thank all for their inputs.
Note that I used the suggested http://www.mbdirectparts.com
Thanks again..
Thanks again..
2010 e550 p2
belarus27
Thanks again..
Thanks again..
whats wrong with it then? since its not the shaft , it is kinda interesting
