Sponsored by: CARiD
2010 e350 command center upgrade?
Old Oct 11, 2016 | 05:39 PM
BENZINO350's Avatar
2010 Mercedes Benz E350 sport 4matic
hi is it possible to upgrade or update the command center in my 2010 e350 to the newer menu or guidance lines for my back up camera ...
maybe even blue tooth audio ???
Old Oct 11, 2016 | 05:58 PM
wrinkles88's Avatar
2010 E550
There's a thread a little lower in the first page. https://mbworld.org/forums/e-class-w...ofit-ngt4.html
Also I have a 2010 that streams via Bt
Old Oct 12, 2016 | 08:49 AM
blegthbloo's Avatar
2013 E550 4Matic
You can activate bluetooth audio streaming in the Engineering Menu... Phone disconnect button + '1' + '#' ... hold them all at the same time for a few seconds while the ignition is in Position 2 (just turn the car on, you could be there for awhile looking through the menus lol)... I think it's in "SW Settings"... the number 7 rings a bell (maybe SW Settings is option 7, or BT audio is option 7 within that menu, or maybe I'm making all this up)
Old Oct 12, 2016 | 09:04 AM
BENZINO350's Avatar
i believe I tried that already and it did not work .
i enabled BT Audio in the engineering menu
Old Oct 12, 2016 | 10:09 AM
belarus27's Avatar
2010 e550 p2
usually that helps with BT audio , maybe double check if you actually activated it.
Old Oct 12, 2016 | 10:26 AM
BENZINO350's Avatar
When I activated it I never saw an option for bt audio in my menu so I just deactivated it
Old Oct 12, 2016 | 10:36 AM
belarus27's Avatar
2010 e550 p2
well there are a few cars that would need it to be activated at dealers i guess it is production date dependable.
you can always buy a bluetooth adapter off ebay for your glove box , or have it activated by someone who got SDS
Old Oct 14, 2016 | 11:17 AM
SafariDan's Avatar
2014 ML 350 4-matic; 2010 E350 4-matic Sport
I have a 2010 E350 which recently (Aug 2016) got updated to the latest possible software it can take (not sure of exact details). Essentially, it can now stream BT Audio as one of the options when pressing "Disc" button. You simply have to reconnect manually every time you get into the car, which is a little annoying but certainly not a deal breaker. Didn't have to make any tweaks under Engineering menu, it all just works now. Of course, my latest iOS beta update and possibly the iPhone 7+ are having a weird issue with the audio breaking up and not streaming properly, but I'm hoping that gets fixed soon... it worked GREAT with my 6+ under iOS 10 GM.
Old Oct 14, 2016 | 01:27 PM
BENZINO350's Avatar
wow thanks for the response !
I called Mercedes and all they said was the 2010 can't stream bt audio.
You would think they would give me more info and let me know if I update software I can stream it..
how much did it cost to upgrade the system?
Old Oct 14, 2016 | 02:35 PM
SafariDan's Avatar
I think it was something like $150 or so, not crazy... it was already in for another service, so just asked them to do it. I will try to find out what the latest COMAND version is on it and get back to you...
Old Oct 14, 2016 | 02:38 PM
BENZINO350's Avatar
Thank you very much I appreciate It!!!
Old Oct 14, 2016 | 02:42 PM
wrinkles88's Avatar
2010 E550
I have a 2010, and an iPhone 6, the bt audio stream connects with in 20 seconds or so of me getting in the car.
Old Oct 14, 2016 | 07:14 PM
belarus27's Avatar
2010 e550 p2
same , around there
Old Oct 16, 2016 | 07:18 PM
SafariDan's Avatar
Think this is the software version here, but not 100% sure... hope that helps!
Old Nov 7, 2016 | 04:19 PM
wgdavis78's Avatar
2010 e350
thats weird... i have a 2010 e350... i stream bluetooth music all day everyday...?? didnt know some of you cant stream.. i have an android one plus phone as well.
Old Dec 12, 2017 | 12:18 PM
Thelalligel's Avatar
MB E350 4Matic
An update to my navigation system failed wiping the Command Center. Now my radio, CD changer and navigation are all down. The dealer said they can't fix it and that I should replace the command center.
Is there anyboby out there who can please help with this?
Old Dec 12, 2017 | 04:56 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
What do you mean by 'all down'? Is there no power to the unit? Have you tried a hard reset by holding in power button until screen goes black and then release to reboot? Did you buy the MB genuine update or a knock off from ebay? If genuine, then you should at least get your money back if it bricked comand.
Old Dec 12, 2017 | 05:12 PM
MB E350 4Matic
I can't play the radio nor the CD player. The navigation nor the phone doesn't work either, and the control knob on the center console doesn't work either. Everything is down since the attempt Nav update.
Old Dec 12, 2017 | 05:14 PM
thefisch's Avatar
Top Answer: 1
If the hard drive was corrupt, I would think the screen would still come up and give you an error message. What happened during the nav update? Did you do it yourself?
Old Dec 12, 2017 | 05:26 PM
MB E350 4Matic
Yes, I did it myself at first, and received an error message after inserting the second disk that said, "unable to complete update", so I took it to the dealer who tried using their update, but it failed also and this is when it wiped the command system. The first set of Disks update I bought from an authorized distributor of MB call HERE. HERE refunded the money.
Old Dec 12, 2017 | 05:58 PM
thefisch's Avatar
Top Answer: 1
So when you tried the update yourself, it failed but comand was still working at that point. But when you took it to dealer, they did the update and while they were working on your car, comand stopped working? If it happened while dealer was working on comand then I'd say they should help you fix it. If not, then get MB corporate involved.
Old Dec 12, 2017 | 06:47 PM
MB E350 4Matic
That's exactly what happened, but they refused to fix it. I will get MB Corporation involve more as you suggested. I did talked to MB customer service who was willing to contribute $1,000 between them and the dealer, which I refused, because the command system cost $5,ooo to replace.
Thank you very much for your helpThefisch!
Old Dec 13, 2017 | 04:14 PM
thefisch's Avatar
Top Answer: 1
Keep us posted.
Old Apr 23, 2023 | 06:08 PM
Viktorius's Avatar
2010 Mercedes Benz E350 Coupe
I activated BT Audio on my 2010 Mercedes E350 Coupe in the Engeneering Menu, so for sure 2010 E350 can stream BT Audio.
