Coolant...
Wonder if I can put in a cup of BMW coolant that I use for my 7 series, + a cup of water, for now until a full coolant flush at next service...?
Advice?
unless there is a leak , take it to dealer. since its still under warranty.
it dont smell like coolant in the car?
It's closer to 2 yrs old & 18,000 miles, so just need to enough to get through until Service B at 20,000 miles...
But just wondering if mixing BMW & Mercedes fluids will affect the engine...
If I was you I would not be worried about what coolant to add. I would be worried why the level is low on a 2 years old car with only 18000 miles on the clock.
My E550 is 7 years old with 120 000 miles on it and I have not seen coolant level go down yet.
You have a leak and if it is not dripping under the car (or on the engine bottom shield in front) you have a way more serious issue with coolant leaking inside the engine. Coolant level does not go down without a leak unless you really "bake" the engine running it very hot for long periods of time when the coolant can evaporate thru the expansion ganister cap. Other than that coolant level should not drop.
If so, it could be a leaking intercooler, which leaks coolant into the engine intake. This happened to the 2003 C32 I own, which has to be replaced as it is not repairable. It was found as a constant slow drop in coolant level, and a green slime in the intake downstream of the intercooler. Common on my car.
Not saying this is your problem, but if no visible external leaks are found, this could be a place to check, as well as anything else plumbed to the system. Take it to the dealer - you are still under warranty.
As for coolant - I'd just add a cup of distilled water and not worry about correct ratios. I have a gallon of MB Blue coolant in the garage for major projects.
http://bevo.mercedes-benz.com
310.1 Coolant Specs
Major assembly model series
M1xx
M2xx
OM6xx
325.0 and 326.0
● ● For all vehicles with a manufacture date up to and including April 2014
Change interval years/km
15/250,000km Whichever occurs first must be observed;
exception: in the vehicle's maintenance manual, different change intervals are stipulated.
I fully agree, let MB SA check as to why the coolant is low to begin with.
