Sponsored by: CARiD
Wiring Help- Trailer Lights
Old Nov 4, 2016 | 08:39 PM
s140s's Avatar
2013 E350 4Matic
Does anyone have any info about the wiring in the back of the tail lights?
I will be installing a PWM Taillight Converter to get 4-Way plug for the trailer electrical.
W212 uses one wire for the tail/ brake lights, one for the turn signal and than the last for the backup light.
There are 4 wires in the back of each tail light and I know that Brown is the ground. I need to know which one is the turn signal and then the combined tail/brake.
This is a PWM converter that does not draw power from the circuit so it will not damage any electronics , modules etc, it only monitors and then amplifies the output via direct connection to the battery.
Old May 31, 2019 | 09:39 PM
cjmeyer's Avatar
2014 e 350
I'm sorry to bother you but did you gt an answer to your question I am trying to do the same thing and can't sort it ou
