Escort 9500ci
Also doing the MidCity remote start.
https://www.escortradar.com/passport9500ci/
and was lmao when i came across this...
"The PASSPORT 9500ci is completely undetectable to all radar detector detectors, keeping you unseen and unnoticed."
totally reminded me of this...the "trace buster buster"...lol
down here, nobody uses anything like that. now im just wonderin', is it still the same concept as before, to detect coppers laser to see if youre speeding? or does it do more than that? coz if thats all it does, wouldnt it be easier to stay under the limit than spend that much money?
The way radar detector protects you is that it pics the radar signal from long distance where it is monitoring other cars ahead of you. It is the scattered signal that the detector sees as the normal radar is quite wide beam.
Laser is a very narrow beam and basically only hits the car it is aimed at. When you get the alarm they already have your speed.
With the normal radar this is the same if the cop keeps the radar off and turns it on just for you when in range. It is too late when the alarm comes on. They know your speed already so on an empty highway radar detector does not help much if the cop's radar is not on continuously.
I would not bother installing laser sensor in the rear. It is quite poor performer in the front also.
The Laser shifter pros (assuming you have the newer version and not the older zr4 jammers which are next to worthless against newer lidar guns), do not protect against the Dragon Variable Pulse Rate LIDAR guns which are in a few areas of ohio already.
Also it appears K-band is present in your area so turning k band off is not a very good idea...
Here is a coverage map: https://www.rdforum.org/wiki/index.p..._Survey_-_Ohio
If you haven't already pulled the trigger, I highly suggest you consider an alternate laser system if not different platform altogether.
You want the AL Priority "ALP" jammers which can be integrated with either the 9500CI head for range, or Beltronics STIR head. (also the new Radenso and some other newer installed system as well). The golden standard system is the Stinger VIP which is neck and neck with the alp on laser and by far the best on radar. but it is $$$$.
If you are able to postpone your install on the radar detector, I'd suggest joining http://www.rdforum.org
Don't get me wrong, the 9500ci is a hell of a detector.... but the jammers that come natively with the system are VERY sensitive to positioning, MUST NOT be obstructed or hidden behind the mesh of your grill, and you will want to find a local member from that forum that will test your setup with a lidar gun and tweak/adjust the heads to ensure you are protected. Fortunately we have largely older LIDAR guns in Minnesota so my older zr4 shifters have been tested and the front has proven to largely but not fully protect me after making some subtle adjustments. They would do nothing against 90% of the guns where you live.
I bought my 9500ci for about 600.00 used. If I were paying the 2k retail cost, I would go a different direction, or buy a used 9500ci that is band segmented and use the alp priority jammers front and rear (I will be adding these at some point).
Also, with jammers, you want to learn the terms "jam to gun" and "jam to kill". When you get hit with Laser, you slow down fast, than turn the jammers off so they can obtain your speed. Jamming to gun they will know it was not a gun glitch, pull you over and give you a ticket or pull your equipment
.Last edited by Tank7; Nov 9, 2016 at 05:11 PM.
You will get great protection from the 9500CI. There is a reason I have it on my own car! Definitely plan on testing the setup!
My rear one gave up. Escort said I can buy a new one for $150 but they never discussed the new fronts ones. What should I do? For $150, it is cheap but should I not bother having rear shifters and spend more to get updated front laser shofter pros? How much should I expect to pay for those?
Amy soldier thank you. I'll get up to speed on the other forum I've been neglecting but earned an intermediate status on.
Cheers
