2016 e350 backup camera (dealer issue)
Anyone recommend a reasonably priced solution? Thanks in advance.
First, look at the FTC cooling off period to see if it applies. Three business days so hurry. https://www.consumer.ftc.gov/article...-rule-may-help CORRECTION - does not apply.
Then, most dealers will have some grace period - some even hold paperwork for 72 business hours just in case they need to back something out. And sometimes financing doesn't get finalized for several days (not sure if you financed).
But time is critical, so if you're going to press the issue, do it today.
Also 3 day right of rescission doesn't apply to cars. Active parking assist is also supposed to include surround view so maybe you can use that when backing up?
Brochure is here so it tends to say there's a camera.
https://www.mbusa.com/vcm/MB/Digital...edan_Wagon.pdf
I had the opposite problem you are having when I searched for one. All had camera, but some didn't have parktronic.
That car has to be a like a 1 of 1, thats bizzare.
Bottom line is if you can't get a W350 car with the options you want from this dealer and you can't unwind the deal, then see if you can get another model MB that's close to what you want for the same cost. Yes it is a trade-off you shouldn't have to make, but if your only E350 option at this dealer is your current car with missing rear view camera or a car that has been involved in an accident, looking at other MB models for a lease isn't that bad. As others have already stated, time is of the essence. However, the longer you wait, the less the dealer in incented to make things right.
What's the build date on this car? I have an earlier build 16 E250, which has both parktronic and camera. I've never seen one like this before.
