Headlight painting.
I imagine many folks just dont care either, though the the whole process is designed to make sure cars have lights that do their job without blinding oncoming traffic.
And if nothing else, before you start to pry them open, you might want to price out what OEM replacements cost. And the stuff that holds them together is RTV, a specialized sealant that is supposed to stay pliable over years.
On the Corvette Forum there is a vendor, RLSebring, who for several years has routinely been replacing headlight transparencies and repainting the headlight assembly interior. In most instances the transparency is damaged e.g., hazed, foggy, road debris ect.
The process, in part, involves heating the headlight assembly so as to soften the adhesive, thereby allowing removal of the transparency.
I'm not the expert, but my recollection is that it is nearly impossible to reuse a transparency once its removed. That said, am guessing that M-B does not stock the transparency as a stand alone item. In order to procure a transparency, one would be required to order a complete headlight assembly. And that would put one back where they started, plus the cost would be outrageous.
Last but not least, aqinob has a very valid point.
A lot of Subaru people do it, but I personally have never done it. Headlights aren't cheap, even for a Subaru, and I wouldn't want to risk resealing them incorrectly and letting moisture in. Not worth the risk imo.
To the poster concerned about DOT approved lights. I'm sure most have replaced their bulbs before. A majority of replacements are not DOT approved, HID is a total different topic.
Going off memory here, I heated the lamps in my oven, one at a time, on the lowest setting (I think it was approximately 140°F), for several minutes. Then I took it to the kitchen table and pulled the housing apart by hand. Not easy, but not terrible either. Just slow so I didn't break anything, and a good workout on your hands/arms...the adhesives are strong.
After I painted what I wanted to, I heated the split housing back in the oven to reactivate the sealant...then pressed them together. Repeated for the other lamp.
Worked perfect, no fog, no cloudiness, like it never happened at all. Very common modification for a lot of makes/models of vehicles. Didn't have to buy any sealants...just a can of semi-gloss black spray paint and some electricity for the oven!
That being said, you can still open them in a couple ways.
You either have to do multiple runs on the over where you bake the headlight, get it out and pry open a section, put it back in the oven, pry open another section. For this method, you can get "cold glue tools" and do it.
The other method would be cutting open the headlights with either a hot knife or a sonic cutter and then plastic weld the headlights back together once done.
Yep I had to get a dremel, and cut at it. Replaced the passenger cover one with some I found on ebay.
Standard headlights might be sealed with butyl, which are fairly easy to open up by "baking." Plenty of threads & tutorials on how to do it.
ILS healdights will most likely be sealed with permaseal which although it is possible to open, I guarantee that you will cry or at least write in despair while attempting to do so.
To determine whether you have butyl or permaseal, look for the black stuff in the channel between the headlight housing and the clear lens. If it's gooey like tar or thick gum, it's butyl - definitely a doable DIY project. (Butyl may also be gray). If the stuff has a texture like tire rubber, it's permaseal.
There are many headlight retrofitters (e.g., the retrofit source) that can do it for you. It's not cheap but considering the work involved, prices are generally reasonable.
And I agree, painting the inside dark doesnt have anything to do with the brightness or range of the lights.
