Sponsored by: CARiD
Suspension Help on 2011 E350 Wagon!**
Old Mar 3, 2017 | 05:01 PM
matman167's Avatar
2017 audi s4
Exclamation Suspension Help on 2011 E350 Wagon!**
So I know there are some threads on here but I wanted to pick everyones brain and get your thoughts! My car over nights sags down pretty low to the wheel well. but when i start it up the compressor raises it up completely fine. but if i let it sit over night, it drops all the way down. from what I'm understanding, its the air spring that needs to be replaced. there must be some leak in the spring. my make and model, (correct me if I'm wrong) does not have the airmatic suspension but a sort of hydraulic suspension. the mechanic is going to do a few tests to see if its possibly a hose leak or something. the air spring retails for $600 !! i found the OE discount parts site for $457 so its obviously better then 600 but still expensive as hell. here is the link. please help me out here and let me know what you think ! i will also post pictures!
https://www.oediscountparts.com/part...?siteid=215242
Old Mar 3, 2017 | 05:04 PM
matman167's Avatar
2017 audi s4
Old Mar 3, 2017 | 06:28 PM
belarus27's Avatar
2010 e550 p2
https://mbworld.org/forums/e-class-w...on-normal.html
https://mbworld.org/forums/e-class-w...ic-please.html
https://mbworld.org/forums/e-class-w...r-springs.html
https://mbworld.org/forums/e-class-w...-problems.html
SOME USEFUL INFO THERE
and im pretty sure you have the same air spring in the rear as 10-11 550s , so it should cost you around 250 if you get one from Arnott or you get a rebuilt one.
check out those threads you will find eveything.
Old Mar 3, 2017 | 06:29 PM
belarus27's Avatar
2010 e550 p2
https://www.arnottindustries.com/par...18_pid224.html
Old Mar 3, 2017 | 06:54 PM
matman167's Avatar
2017 audi s4
Thank you ! So did I buy the wrong part ? I gave them my VIN , make model and they gave me something a little different . $457 is a bit steep but it's a lot better then $600!
Old Mar 4, 2017 | 01:30 AM
belarus27's Avatar
2010 e550 p2
Im pretty sure its the right part since they used the VIN number.
Maybe theycare somewhat different between wagon and sedan.
Yours is the 2nd wagon i know that has airmatic lol
belarus27's Avatar
2010 e550 p2
Post pictures of the new ones
Old Mar 4, 2017 | 03:00 PM
matman167's Avatar
2017 audi s4
Yea my wagon is different . I gave them the VIN. Anyway the parts will be in Tuesday or Wednesday. I'll post pictures when it's done .
Old Mar 4, 2017 | 08:05 PM
msgadget's Avatar
530i, C300,
hi matman, if you have a issue with the parts...there is not an issue.. you have my number!
Old Mar 4, 2017 | 08:54 PM
matman167's Avatar
2017 audi s4
Msgadget, not sure what you mean ??
Old Mar 4, 2017 | 10:35 PM
msgadget's Avatar
530i, C300,
This is Tracy
Old Mar 4, 2017 | 10:43 PM
matman167's Avatar
2017 audi s4
That is So funny, Hi Tracy! Just had to post a few pics and ask some veteran MB owners there two cents, and to also see if there are any underlining issues. You've been a life saver for me!!
