Sponsored by: CARiD
Extended Warranty is About to Expire
Old Mar 4, 2017 | 09:37 AM
Csskrillz05's Avatar
2011 E550 Sedan, black, P2, AMG wheels
Good morning Gents,
I have a 2011 E550, P2, Airmatic with 97,000 miles.
So far the repairs that have been made are
- Command control knob replacement
- Starter replacement
- Thermostat
- Camshaft vent oil leak
- Airmatic compressor
As my warranty will be expiring 100,000 miles, is there anything I should try to get fixed or replaced before my time is up? the airmatic shocks look ok. my mechanic advised that maybe we should do the intake manifold as he said those are prone to going back due to some plastic parts that break.
anything else I should be on the look out for?
Old Mar 5, 2017 | 02:08 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
I would check every feature (i.e. seat heaters, roller shade, etc.) and use several times to make sure there are no issues. Also if you have a pano roof, go over some speed bumps at an angle to check for popping.
Are you planning to keep car out of warranty?
Old Mar 6, 2017 | 09:31 PM
OnlyGerman's Avatar
Too many german broads
Originally Posted by Csskrillz05
Good morning Gents,
- Thermostat
Thought they fixed the plastic flap issue in the w212 intake manifolds? Had it replaced in my w211.
Old Mar 19, 2017 | 02:26 AM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
Good morning Gents,
- Thermostat
check your wood. If you have the burl walnut wood trim. They tend to fade
Old Mar 19, 2017 | 02:46 PM
Pntblnk's Avatar
2017 S550 Iridium / Black Nappa, 2015 GL 550 Paladium Silver
If your airmatic is all good then there isn't much left to check. Sounds like you have had great luck with the ride. Congrats.
Old Mar 19, 2017 | 06:32 PM
cetialpha5's Avatar
Usually that's not covered by the extended or CPO warranty, just the new car warranty because it's considered cosmetic. Make sure seat heaters work and just have the car scanned for any codes. I think alternators also go in that mileage range.
