Right Daytime Running Lights Fuse Replacement Help
I'm having issues with my passenger side daytime running lights, they will not work at all.
Can I assume that a fuse might have blown out?
Is it the fuse? If so, what is it called on the fuse allocation chart? Which fuse box will I be looking at? Which position and fuse?
How does the entire right DRL light go out?
I recently replaced my right parking light.. did it trigger the right DRL to go out?
Any help or suggestions would be much appreciated.
Thank you
