Feedback needed on suspension dropping issue 2011 E350
And you mentioned that all 4 sides go low on air , which should indicate either a leak in compressor or air lines. Otherwise only 1(in most cases) side would sag.
good luck and keep us updated.
and you said you got 2 rear ones replaced so obviously there is another leak in the system. mine stays the same within a day or 2...or 5.
i can only speak for the rear air bags since im sure they are similar to my air bags
...... OR check/inspect the compressor and air lines that connect to it for any visible issues or maybe air hissing sound.
