spacer recomendation
I decided to go with a bit more size wall for a better ride and know the speedo will be off a bit.
As far as spacers. For your wheels (if they fit due to tire's diameter that normally does not fit non-airmatic W212s), no spacers for the front and 10mm spacers for the rear.
For stock (et48) wheels: 5mm front with 15mm rear; or ideally 10mm front with 20mm rear.
