Sponsored by: CARiD
Dead Battery?
Old Mar 28, 2017 | 06:26 PM
Yosheego's Avatar
2011 E550
Dead Battery?
Hey guys,
I got this issues this morning. Looking to see I can get some help before I make the move to call the dealer. From what I read, looks like a dead battery. I didn't want to jump start it, thinking it could cause other issues. Any input/advice would be greatly appreciated!
https://chandoan.smugmug.com/Cars/11...50/i-nX5pxd6/A
Old Mar 29, 2017 | 10:25 AM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
Wow, I've never seen that before. I don't have speakers at my current location so I couldn't hear any of the sound. Hopefully someone will come by that has seen this before and has advice. Good luck.
Old Mar 30, 2017 | 04:11 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
might be the F32 fuse issue. Check out this thread: https://mbworld.org/forums/e-class-w...d-respond.html
Old Mar 30, 2017 | 09:40 PM
NSKPhila's Avatar
2018 E300 & 2004 CLK500
had the backward clock thing happen on my clk500.. ignition would click but that was all. battery was 3 yrs old.. called MB roadside, they came out, tested the battery, put a new one in and reset the windows, then tested the charging - cost me 177 total. I was back up and running in an hour.
Old Aug 15, 2017 | 09:44 PM
- Mover -'s Avatar
E550
My battery charge was getting low and I had weird stuff starting to happen as well. The Parking sensor system would go into malfunction mode.
I went and picked up a new battery, however, when the shop tested the old one they said it was still good but not fully charged !
I've done a lot of short trips this month and from what I understand, the alternator charges in a way that is suppose to be efficient and 'smart'. (So much for a smart charging system )
Anyway, I tapped into the Engineering menus and found out where I could monitor Battery Voltage while I was driving. I messed around a bit and figured out how I could get the alternator to kick in when I want to and have the voltage up to 15 V.
Old Aug 15, 2017 | 09:54 PM
thefisch's Avatar
Top Answer: 1
These AGM batteries can pass a basic test with their battery readers. You really need a load test to expose that there are not enough amps left.
What did you do to get the alternator to kick into high gear? I found that WOT worked.
Old Aug 19, 2017 | 09:32 AM
- Mover -'s Avatar
E550
WOT is probably better than the method I was using. I'd hit the AC and the voltage would move up right away.
